【数学建模】基于matlab GUI随机节点的生成树【含Matlab源码 1919期】
海神之光 发表于 2022/06/27 23:41:01 2022/06/27
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab GUI随机节点的生成树【含Matlab源码 1919期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = main(varargin)
% MAIN M-file for main.fig
%      MAIN, by itself, creates a new MAIN or raises the existing
%      singleton*.
%      H = MAIN returns the handle to a new MAIN or the handle to
%      MAIN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MAIN.M with the given input arguments.
%      MAIN('Property','Value',...) creates a new MAIN or raises the
%      applied to the GUI before main_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to main_OpeningFcn via varargin.
% Edit the above text to modify the response to help main
% Last Modified by GUIDE v2.5 26-Jun-2022 10:35:54
gui_Singleton = 1;
                   'gui_OpeningFcn', @main_OpeningFcn, ...
                   'gui_OutputFcn',  @main_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before main is made visible.
function main_OpeningFcn(hObject, eventdata, handles, varargin)
global hds
global hpg hpt hps hpnn % graph handles, tree handles, start point handle, nodes numbers
global rr % to meorize r - nodes positions
% Choose default command line output for main
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
hds=handles;
set(hds.figure1,'MenuBar','figure','Toolbar','figure');
set(hds.axes1,'NextPlot','Add');
axis(hds.axes1,'equal');
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/125470382
