springboot05、封装返回结果集{state:““msg:““result:null}
红目香薰 发表于 2022/06/26 20:13:12 2022/06/26
【摘要】 ​ ​编辑springboot05、封装结果集不可能一直用map写数据返回,很麻烦的,那么咱们就可以进行一次封装此次使用。目录springboot05、封装结果集创建【com.item.res】包注意问题编辑一个SUCCESS类和ERROR类,他们都有state、msg、result,那么就创建一个公用的父类base。创建【com.item.res】包Base:package com.ite...
 ​编辑
springboot05、封装结果集
目录
springboot05、封装结果集
创建【com.item.res】包
注意问题
创建【com.item.res】包
Base:
package com.item.res;
public class BASE {
    private boolean state;
    private String msg;
    private Object result;
    public BASE(boolean state, String msg, Object result) {
        this.state = state;
        this.msg = msg;
        this.result = result;
    public boolean isState() {
        return state;
    public void setState(boolean state) {
        this.state = state;
    public String getMsg() {
        return msg;
    public void setMsg(String msg) {
        this.msg = msg;
    public Object getResult() {
        return result;
    public void setResult(Object result) {
ERROR:
public class ERROR extends BASE {
    public ERROR(String msg, Object result) {
        super(false, msg, result);
SUCCESS:
public class SUCCESS extends BASE {
    public SUCCESS(Object result) {
        super(false, "操作成功", result);
返回修改:
package com.item.controller;
import com.item.model.Users;
import com.item.res.ERROR;
import com.item.res.SUCCESS;
import com.item.service.UsersService;
import io.swagger.annotations.Api;
import io.swagger.annotations.ApiImplicitParam;
import io.swagger.annotations.ApiImplicitParams;
import io.swagger.annotations.ApiOperation;
import org.apache.commons.lang3.StringUtils;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.ui.Model;
import org.springframework.web.bind.annotation.*;
import javax.servlet.http.HttpServletRequest;
import java.util.HashMap;
import java.util.List;
@Api("用户操作接口")
@RestController
@CrossOrigin
public class UsersController {
    @Autowired
    private UsersService usersService;
     * 获取所有信息
     * @return
    @GetMapping("/GetInfoApi")
    @ApiOperation(value = "获取信息",notes = "没啥留言的")
    public Object GetInfoApi(){
        List<Users> list=usersService.GetInfo();
        return new SUCCESS(list);
    @GetMapping("/GetName")
    @ApiImplicitParams({
            @ApiImplicitParam(name = "nickName",required = true,paramType = "query",dataType = "String",value = "通过昵称模糊查询")
    public Object GetName(HttpServletRequest request,Model model){
        String nickName = request.getParameter("nickName");
        List<Users> list=usersService.SelectName(nickName);
     * 添加信息
     * @param userName
     * @param pwd
     * @param nickName
     * @return
    @PostMapping(value = "/UserAddInfoApi")
    @ApiOperation(value = "添加",notes = "没啥留言的")
            @ApiImplicitParam(name = "userName",required = true,paramType = "query",dataType = "String",value = "用户名"),
            @ApiImplicitParam(name = "pwd",required = true,paramType = "query",dataType = "String",value = "密码"),
            @ApiImplicitParam(name = "nickName",required = true,paramType = "query",dataType = "String",value = "昵称")
    public Object UserAddInfoApi(String userName,String pwd,String nickName){
        HashMap<String,Object> map=new HashMap<String,Object>();
        if(
                StringUtils.isEmpty(userName)||
                StringUtils.isEmpty(pwd)||
                StringUtils.isEmpty(nickName)
            return new ERROR("参数为空","参数错误");
        usersService.UsersAddInfo(userName, pwd, nickName);
        return new SUCCESS("添加成功");
     * 单个查询
     * @param id
     * @return
    @GetMapping("/UsersSelectById")
    @ApiOperation(value = "id查询",notes = "没啥留言的")
            @ApiImplicitParam(name = "id",required = true,paramType = "query",dataType = "String",value = "编号")
    public Object UsersSelectById(String id){
        Users users = usersService.UsersSelectById(Integer.parseInt(id));
        map.put("state",true);
        map.put("msg","成功");
        map.put("result",users);
        return map;
     * 修改api
     * @param id
     * @param pwd
     * @return
    @PostMapping(value = "/UserUpdateInfoApi")
            @ApiImplicitParam(name = "id",required = true,paramType = "query",dataType = "String",value = "编号"),
    public Object UserUpdateInfoApi(String id,String pwd){
        usersService.UsersUpdateInfo(pwd,Integer.parseInt(id));
        map.put("result","");
        return map;
     * 删除api
     * @param id
     * @return
    @GetMapping(value = "/UsersDeleteById")
    @ApiOperation(value = "根据id删除",notes = "没啥留言的")
    public Object UsersDeleteById(String id){
        usersService.UsersDeleteById(Integer.parseInt(id));
        return map;
使用swagger访问测试返回效果如下:
​编辑
设置完成。
注意问题:
每个人的习惯方式均不同,需要看看公司具体用什么方式:
也可能是这样返回:
“code”: -9999,
“message”: “Invalid Request”,
“data”:{ }
注意:无论是【ERROR】还是【SUCCESS】他们的返回结果都需要一致,否则前端在处理的时候就会很麻烦,对是一套解析,错又是一套解析,很麻烦。
例如:
正确返回:
"state": true,
"message": "访问成功",
"data":
      "id": 77,
      "userName": "子玉等于摸鱼",
      "pwd": "074FD28EFF0F5ADEA071694061739E55",
      "nickName": "高大上,牛逼吼吼吼吼吼"
错误返回:
"state": false,
"message": "访问失败",
"data":"失败"
这就没法玩了。。。。 会挨骂的。
避免层级过深的URI
/ 在url中表达层级,用于按实体关联关系进行对象导航,一般根据id导航。
过深的导航容易导致url膨胀,不易维护,如 GET /zoos/1/areas/3/animals/4,尽量使用查询参数代替路劲中的实体导航,如GET /animals?zoo=1&area=3。
结果过滤,排序,搜索
url最好越简短越好,对结果过滤、排序、搜索相关的功能都应该通过参数实现。
过滤:例如你想限制GET /tickets 的返回结果:只返回那些open状态的ticket, GET /tickets?state=open 这里的state就是过滤参数。
排序:和过滤一样,一个好的排序参数应该能够描述排序规则,而不和业务相关。复杂的排序规则应该通过组合实现。排序参数通过 , 分隔,排序参数前加 - 表示降序排列。
