孙老师版本JDBC(2022年6月12日21:34:25)
红目香薰 发表于 2022/06/26 20:10:00 2022/06/26
【摘要】 ​ 数据库自动关闭,方便多了。package com.item.dao;import java.sql.Connection;import java.sql.DriverManager;import java.sql.ResultSet;import java.sql.SQLException;public class JDBCUtil implements AutoCloseable { ...
 数据库自动关闭,方便多了。
	private static String driver="com.mysql.jdbc.Driver";
	private static String url="jdbc:mysql://127.0.0.1:3306/mytest?characterEncoding=utf-8";
	// 连接对象
	private static Connection conn;
	// 结果集
	private static ResultSet rs;
	// 代码块
	static{
		try {
			Class.forName(driver);
			conn = DriverManager.getConnection(url, "root", "12345678");
		} catch (Exception e) {
			e.printStackTrace();
	 * 全SQL查询
	 * @param sql
	 * @return
	 * @throws SQLException
	public static ResultSet query(String sql) throws SQLException {
		return conn.createStatement().executeQuery(sql);
	 * @param sql
	 * @return
	public static int update(String sql) throws SQLException {
		return conn.prepareStatement(sql).executeUpdate();
	@Override
	public void close() throws Exception {
		if (null != rs) {
			rs.close();
		if (null != conn) {
			conn.close();
数据测试:
	public static void main(String[] args) throws SQLException {
		ResultSet re = query("select * from users");
		while (re.next()) {
			System.out.println(re.getObject(1));
			System.out.println(re.getObject(2));
			System.out.println(re.getObject(3));
			System.out.println(re.getObject(4));
			System.out.println(re.getObject(5));
编辑
swing
	 * 转换为Vectors集合
	 * @param userList
	 * @return
	public static Vector<Vector<String>> listToVectors(List<UserVo> userList) {
		Vector<Vector<String>> datas = new Vector<Vector<String>>();
		for (int i = 0; i < userList.size(); i++) {
			UserVo u = userList.get(i);
			if (null == u)
				continue;
			Vector<String> item = new Vector<String>();
			item.add(u.getId().toString());
			item.add(u.getAccount());
			item.add(u.getSex() == 1 ? "男" : "女");
			item.add(u.getEducation());
			item.add(u.getPhone());
			item.add(u.getEmail());
			item.add(u.getRegisterDate());
			if (null == u.getUpdateDate()) {
				item.add("");
			}else {
				item.add(u.getUpdateDate());
			datas.add(item);
		return datas;
三行实现JTable数据更新。
datas.clear();
datas.addAll(ListDbUtils.listToVectors(userService.list()));
jTable.updateUI();
JTable jTable = new JTable(datas, heads);
这个方便快捷一些,但是javaEE的还没有测试。后面我搞个完整的就都知道了。
