[华为云在线课程][Spring入门][JdbcTemplate和事务简介][三][学习笔记]
John2021 发表于 2022/06/26 06:07:59 2022/06/26
【摘要】 1.JdbcTemplateJdbcTemplate是Spring利用AOP封装的JDBC操作工具。 1.1.准备工作首先要添加jdbc相关的依赖<dependencies> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-context</artifactId>...
1.JdbcTemplate
1.1.准备工作
首先要添加jdbc相关的依赖
<dependencies>
    <dependency>
        <version>5.3.20</version>
    </dependency>
    <dependency>
        <artifactId>spring-jdbc</artifactId>
    </dependency>
    <dependency>
        <groupId>mysql</groupId>
        <artifactId>mysql-connector-java</artifactId>
        <version>8.0.29</version>
    </dependency>
</dependencies>
然后创建数据库testjdbctemplate
CREATE TABLE `user` (
  `id` int NOT NULL AUTO_INCREMENT,
  `username` varchar(255) COLLATE utf8mb4_general_ci DEFAULT NULL,
  `address` varchar(255) COLLATE utf8mb4_general_ci DEFAULT NULL,
  PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=5 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_general_ci"
INSERT INTO `user`(username,address)
VALUES ('hello','beijing'),('world','shanghai'),('nihao','guangzhou'),('a','shenzhen');
完成数据库创建后新建一个实体类User
package org.jdbctemplate;
public class User {
    private Integer id;
    private String username;
    private String address;
    public User() {
    public User(Integer id, String username, String address) {
        this.id = id;
        this.username = username;
        this.address = address;
    public Integer getId() {
        return id;
    public void setId(Integer id) {
        this.id = id;
    public String getUsername() {
        return username;
    public void setUsername(String username) {
    public String getAddress() {
        return address;
    public void setAddress(String address) {
    @Override
    public String toString() {
        return "User{" +
                "id=" + id +
                ", username='" + username + '\'' +
                ", address='" + address + '\'' +
1.2.Java配置
编写一个Java配置类,在配置类中配置JdbcTemplate
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.jdbc.core.JdbcTemplate;
import org.springframework.jdbc.datasource.DriverManagerDataSource;
import javax.sql.DataSource;
@Configuration
public class JdbcConfig {
    * 这个是数据库配置信息的Bean
    @Bean
    DataSource dataSource() {
        DriverManagerDataSource dataSource = new DriverManagerDataSource();
        dataSource.setDriverClassName("com.mysql.cj.jdbc.Driver");
        dataSource.setUsername("root");
        dataSource.setPassword("1234");
        dataSource.setUrl("jdbc:mysql:///test01");
        return dataSource;
    * 这个是JdbcTemplate的Bean
    * 只需要new一个Bean出来,配置DataSource就可以了
    @Bean
    JdbcTemplate jdbcTemplate() {
        return new JdbcTemplate(dataSource());
编写启动类
import org.junit.Before;
import org.junit.Test;
import org.springframework.context.annotation.AnnotationConfigApplicationContext;
import org.springframework.jdbc.core.BeanPropertyRowMapper;
public class Main {
    private JdbcTemplate jdbcTemplate;
    @Before
    public void before() {
        AnnotationConfigApplicationContext applicationContext = new AnnotationConfigApplicationContext(JdbcConfig.class);
        jdbcTemplate = applicationContext.getBean(JdbcTemplate.class);
    @Test
    public void select() {
        User user = jdbcTemplate.queryForObject("select * from test01.user where username=?",
                new BeanPropertyRowMapper<User>(User.class),"hello");
        System.out.println(user);
    @Test
    public void insert() {
        jdbcTemplate.update("insert into test01.user(username, address) values (?,?);",
                "new01", "diqiu");
    @Test
    public void update() {
        jdbcTemplate.update("update test01.user set username=? where id=?",
                "new001", 5);
    @Test
    public void delete() {
        jdbcTemplate.update("delete from test01.user where id=?",
                5);
如果是使用了BeanPropertyRowMapper来查询,要求查出来的字段必须和Bean的属性名一一对应。如果不是就需要自定义RowMapper或者给查询的字段取别名。
给查询出的列取别名
@Test
public void selectAlias() {
    User user = jdbcTemplate.queryForObject("select id,username as name,address from test01.user where id=?",
            new BeanPropertyRowMapper<>(User.class), 1);
    System.out.println(user); //User{id=1, username='null', address='beijing'}
自定义RowMapper
@Test
public void rowMapper() {
    User user = jdbcTemplate.queryForObject("select * from test01.user where id=?",
            new RowMapper<User>() {
                @Override
                public User mapRow(ResultSet rs, int rowNum) throws SQLException {
                    int id = rs.getInt("id");
                    String username = rs.getString("username");
                    String address = rs.getString("address");
                    User u = new User();
                    u.setId(id);
                    u.setUsername(username);
                    u.setAddress(address);
                    return u;
            }, 1);
    System.out.println(user); //User{id=1, username='hello', address='beijing'}
如果要查询多条记录,代码如下
@Test
public void selectMultiple() {
    List<User> userList = jdbcTemplate.query("select * from test01.user", new BeanPropertyRowMapper<>(User.class));
    System.out.println(userList);
    // [User{id=1, username='hello', address='beijing'},
    // User{id=2, username='world', address='shanghai'},
    // User{id=3, username='nihao', address='guangzhou'},
    // User{id=4, username='a', address='shenzhen'}]
1.3.XML配置
也可以通过Spring配置文件来实现配置。通过XML文件实现只是提供JdbcTemplate实例,JdbcConfig被Spring配置文件替代。
<!--    JdbcTemplateXML-->
<bean class="org.springframework.jdbc.datasource.DriverManagerDataSource" id="dataSource">
    <property name="username" value="root"/>
    <property name="password" value="1234"/>
    <property name="url" value="jdbc:mysql:///test01?serverTimezone=Asia/Shanghai"/>
    <property name="driverClassName" value="com.mysql.cj.jdbc.Driver"/>
</bean>
<bean class="org.springframework.jdbc.core.JdbcTemplate" id="jdbcTemplate">
    <property name="dataSource" ref="dataSource"/>
</bean>
编写启动类
import org.springframework.context.support.ClassPathXmlApplicationContext;
import org.springframework.jdbc.core.RowMapper;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.util.List;
public class MainXML {
    @Before
        ClassPathXmlApplicationContext applicationContext = new ClassPathXmlApplicationContext("applicationcontext.xml");
    @Test
                "new001", "001address");
    @Test
                "new002", 6);
    @Test
        jdbcTemplate.update("delete from test01.user where id=?", 6);
    @Test
    @Test
    public void selectAll() {
    @Test
    public void select2() {
    @Test
    public void select3() {
                    @Override
                        User user = new User();
                        user.setId(id);
                        user.setUsername(username);
                        user.setAddress(address);
                        return user;
                },1);
2.事务
Spring中的事务主要利用AOP来简化事务的配置,可以通过XML配置,也可以通过Java配置。下面通过一个经典的场景-转账,来演示Spring中的事务配置。
create table `account`(
    `id` int(11) not null auto_increment,
    `username` varchar(255) default null,
    `money` int(11) default null,
    primary key (`id`)
)engine=InnoDB auto_increment=3 default charset=utf8mb4 collate=utf8mb4_general_ci;
insert into `account`(id, username, money)
values (1, 'zhangsan', 1000),
       (2, 'lisi', 1000);
@Configuration
    * 这个是数据库配置信息的Bean
    @Bean
        return dataSource;
    @Bean
</bean>
</bean>
编写转账方法
package org.transaction;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Repository;
@Repository
public class UserDao {
    @Autowired
    public void addMoney(String username, Integer money) {
        jdbcTemplate.update("update test01.account set money=money+? where username=?",
                money, username);
    public void minmoney(String username, Integer money) {
        jdbcTemplate.update("update test01.account set money=money-? where username=?",
                money, username);
import org.springframework.stereotype.Service;
@Service
public class UserService {
    @Autowired
    UserDao userDao;
    public void updateMoney() {
        userDao.addMoney("zhangsan", 200);
        int i = 1 / 0;
        userDao.minmoney("list", 200);
最后开启自动化扫描
</bean>
</bean>
<!--    开启自动扫描-->
<context:component-scan base-package="org.transaction"/>
import org.springframework.context.annotation.ComponentScan;
@Configuration
@ComponentScan(basePackages = "org.transaction")
    * 这个是数据库配置信息的Bean
    @Bean
        return dataSource;
    @Bean
2.1.XML配置
XML配置事务有三个步骤:1,配置TransactionManager。2,配置事务要处理的方法。3,配置AOP。
<bean class="org.springframework.jdbc.datasource.DataSourceTransactionManager" id="transactionManager">
</bean>
配置事务要处理的方法
<tx:advice id="txAdvice" transaction-manager="transactionManager">
    <tx:attributes>
        <tx:method name="update*"/>
        <tx:method name="insert*"/>
        <tx:method name="add*"/>
        <tx:method name="delete*"/>
    </tx:attributes>
</tx:advice>
    一旦配置了方法名称规则之后,service中的方法一定要按照名称规则命名,不然事务配置不会生效。
配置AOP
<aop:config>
    <aop:pointcut id="pc1" expression="execution(* org.transaction.service.*.*(..))"/>
    <aop:advisor advice-ref="txAdvice" pointcut-ref="pc1"/>
</aop:config>
import org.transaction.service.UserService;
public class Main {
    private UserService userService;
    @Before
        userService = applicationContext.getBean(UserService.class);
    @Test
    public void test1() {
        userService.updateMoney();
2.2.Java配置
Spring配置文件中的配置
<!--    Java配置事务-->
<!--    配置TransactionManager-->
<bean class="org.springframework.jdbc.datasource.DataSourceTransactionManager" id="transactionManager"/>
<tx:annotation-driven transaction-manager="transactionManager"/>
这行配置可以代替<tx:advice>和<aop:config>
然后在UserService上添加事务注解@Transactional注解,表示在某个方法开启事务,如果把注解放到类上就是为所有方法开启事务
package org.transaction.service;
import org.springframework.transaction.annotation.Transactional;
import org.transaction.dao.UserDao;
@Service
    @Autowired
    UserDao userDao;
    @Transactional
        int i = 1 / 0;
public class Main {
    @Before
        //ClassPathXmlApplicationContext applicationContext = new ClassPathXmlApplicationContext("applicationcontext.xml");
    @Test
