Rancher入门到精通-2.0 nginx-ingress启动失败
隔壁老汪 发表于 2022/06/26 00:16:31 2022/06/26
【摘要】 -------------------------------------------------------------------------------NGINX Ingress controller Release: 0.21.0-rancher3 Build: Repository: https://github...
  1. -------------------------------------------------------------------------------
  2. NGINX Ingress controller
  3. Release: 0.21.0-rancher3
  4. Build:
  5. Repository: https://github.com/rancher/ingress-nginx.git
  6. -------------------------------------------------------------------------------
  7. nginx version: nginx/1.15.6
  8. W1028 07:56:01.718647 9 client_config.go:548] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
  9. I1028 07:56:01.718867 9 main.go:196] Creating API client for https://10.43.0.1:443
  10. I1028 07:56:01.725006 9 main.go:240] Running in Kubernetes cluster version v1.14 (v1.14.5) - git (clean) commit 0e9fcb426b100a2aea5ed5c25b3d8cfbb01a8acf - platform linux/amd64
  11. I1028 07:56:01.728748 9 main.go:101] Validated ingress-nginx/default-http-backend as the default backend.
  12. I1028 07:56:01.999766 9 nginx.go:258] Starting NGINX Ingress controller
  13. I1028 07:56:02.006367 9 event.go:221] Event(v1
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/102782747
