以太坊开发教程- truffle安装
隔壁老汪 发表于 2022/06/24 23:21:48 2022/06/24
【摘要】 waterwdeMacBook-Pro:mytoken waterw$ npm install -g trufflenpm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/trufflenpm ERR! path /usr/local/l...
  1. waterwdeMacBook-Pro:mytoken waterw$ npm install -g truffle
  2. npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/truffle
  3. npm ERR! path /usr/local/lib/node_modules/truffle
  4. npm ERR! code EACCES
  5. npm ERR! errno -13
  6. npm ERR! syscall access
  7. npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/truffle'
  8. npm ERR! { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/truffle']
  9. npm ERR! stack:
  10. npm ERR! "Error: EACCES: permission denied, access '/usr/local/lib/node_modules/truffle'",
  11. npm ERR! errno: -13,
  12. npm ERR! code: 'EACCES',
  13. npm ERR! syscall: 'access',
  14. npm ERR! path: '/usr/local/lib/node_modules/truffle' }
  15. npm ERR!
  16. npm ERR! The operation was rejected by your operating system.
  17. npm ERR! It is likely you do not have the permissions to access this file as the current user
  18. npm ERR!
  19. npm ERR! If you believe this might be a permissions issue,
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/94819805
