Rancher入门到精通-2.0 Nginx ingress配置
隔壁老汪 发表于 2022/06/25 00:20:04 2022/06/25
【摘要】 keycloak is exposed on "/auth" which is the default web-context. I understand that as default web-context, means that you want everything sent to / sho...
  • I understand that as default web-context, means that you want everything sent to / should be redirected to keycloak.
  • So you need to set a different target for Sentry, like /sentry.
  • kubernetes.io/ingress.class: sentry-nginx is not a valid ingress.class in kubernetes.io that's probably why your ingress is not being considered.
  • Only one deployment of Nginx-Ingress is needed to proxy traffic between multiple apps.
  • The trick here is to expose sentry as mydomain.com/sentry and the app itself receives the connection directly on / as required.
In order to achieve it you can use rewrite-target, learn more here.
  • It will creat
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/106925008
