RabbitMq从入门到精通- reply-code=406, reply-text=PRECONDITION_FAILED
隔壁老汪 发表于 2022/06/25 00:41:39 2022/06/25
【摘要】   [WARN ] 2020-05-07 09:53:32,699 [SimpleAsyncTaskExecutor-20] o.s.a.r.l.SimpleMessageListenerContainer - Consumer raised exception, processing can restart if the ...
[WARN ] 2020-05-07 09:53:32,699 [SimpleAsyncTaskExecutor-20] o.s.a.r.l.SimpleMessageListenerContainer - Consumer raised exception, processing can restart if the connection factory supports it
com.rabbitmq.client.ShutdownSignalException: channel error; protocol method: #method<channel.close>(reply-code=406, reply-text=PRECONDITION_FAILED - unknown delivery tag 1, class-id=60, method-id=80)
    at com.rabbitmq.client.impl.ChannelN.asyncShutdown(ChannelN.java:505)
    at com.rabbitmq.client.impl.ChannelN.processAsync(ChannelN.java:336)
    at com.rabbitmq.client.impl.AMQChannel.handleCompleteInboundCommand(AMQChannel.java:143)
    at com.rabbitmq.client.impl.AMQChannel.handleFrame(AMQChannel.java:90)
    at com.rabbitmq.client.impl.AMQConnection.readFrame(AMQConnection.java:634)
    at com.rabbitmq.client.impl.AMQConnection.access$300(AMQConnection.java:47)
    at com.rabbitmq.client.impl.AMQConnection$MainLoop.run(AMQConnection.java:572)
    at java.lang.Thread.run(Thread.java:748)
channel.basicAck(deliveryTag,false);
  1. rabbitmq:
  2. host: 192.168.0.222
  3. port: 5672
  4. username: test
  5. password: test
  6. publisher-confirms: true
  7. virtual-host: /
  8. listener:
  9. simple:
  10. acknowledge-mode: manual
  11. concurrency: 10 # 消费者数量
  12. max-concurrency: 10 # 消费者最大数量
  13. prefetch: 1 # 消费者每次从队列中取几个消息
  14. auto-startup: true # 启动时自动启动消费者
  15. default-requeue-rejected: true # 消息消费失败后,重新进入消费队列中
  16. retry:
  17. enabled: true # 启用发布重试
  18. initial-interval: 1000 # 1秒后重试
  19. max-attempts: 3 # 传递消息的最大尝试次数
  20. max-interval: 10000 # 尝试的最大时间间隔
  21. multiplier: 1.0 # 应用于先前传递重试时间间隔的乘数
注释掉
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/105966144
