Springboot入门到精通- springboot封装工具类,需要获取配置中的参数
隔壁老汪 发表于 2022/06/24 23:41:38 2022/06/24
【摘要】 @Component @ConditionalOnProperty(prefix = "jwt", name = "enable",havingValue = "true") public class JwtUtil { private static String header = ""; private static S...
@Component
   private static String username = "";
   private static String password = "";
   @Autowired
   private Environment env;
   public JwtUtil(Environment env) {
      this.env = env;
   @PostConstruct
   public void config() {
      url = env.getProperty("spring.datasource.url");
      username = env.getProperty("spring.datasource.username");
      password = env.getProperty("spring.datasource.password");
注意加开关
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/119829185
