oracle中char与varchar2的区别
隔壁老汪 发表于 2022/06/25 00:00:20 2022/06/25
【摘要】 1. CHAR的长度是固定的,而VARCHAR2的长度是可以变化的,比如,存储字符串“abc",对于CHAR (20),表示你存储的字符将占20个字节(包括17个空字符),在数据库中它是以空格占位的,而同样的VARCHAR2 (20)则只占用3个字节的长度,20只是最大值,当你存储的字符小于20时,按实际长度存储。 2.CHAR的效...
SQL> desc sys.standard.decodeParameter Type                    Mode Default?--------- ----------------------- ---- --------(RESULT)  NUMBER                                EXPR      NUMBER                  IN            PAT       NUMBER                  IN            RES       NUMBER                  IN            (RESULT)  VARCHAR2                              EXPR      NUMBER                  IN            PAT       NUMBER                  IN            RES       VARCHAR2                IN            (RESULT)  DATE                                 EXPR      NUMBER                  IN            PAT       NUMBER                  IN            RES       DATE                    IN            (RESULT)  NUMBER                                EXPR      VARCHAR2                IN            PAT       VARCHAR2                IN            RES       NUMBER                  IN            (RESULT)  VARCHAR2EXPR      VARCHAR2                INPAT       VARCHAR2                IN  RES       VARCHAR2                IN  (RESULT)  DATE                                 EXPR      VARCHAR2                IN            PAT       VARCHAR2                IN            RES       DATE                    IN            (RESULT)  NUMBER                                EXPR      DATE                    IN            PAT       DATE                    IN            RES       NUMBER                  IN            (RESULT)  VARCHAR2                              EXPR      DATE                    IN            PAT       DATE                    IN            RES       VARCHAR2                IN            (RESULT)  DATE                                 EXPR      DATE                    IN            PAT       DATE                    IN            RES       DATE                    IN            (RESULT)  SYS.STANDARD.<ADT_1>                  EXPR      SYS.STANDARD.<ADT_1>    IN            PAT       SYS.STANDARD.<ADT_1>    IN            RES       SYS.STANDARD.<ADT_1>    IN            (RESULT)  SYS.STANDARD.<OPAQUE_1>               EXPR      SYS.STANDARD.<OPAQUE_1> IN            PAT       SYS.STANDARD.<OPAQUE_1> IN            RES       SYS.STANDARD.<OPAQUE_1> IN
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/84434927
