以太坊智能合约开发
隔壁老汪 发表于 2022/06/24 23:19:27 2022/06/24
【摘要】 $ npm install -g truffle C:\Users\wangxb147\AppData\Roaming\npm\truffle -> C:\Users\wangxb147\AppData\Roaming\npm\node_modules\truffle\build\cli.bundled.js > truf...
> truffle@5.0.26 postinstall C:\Users\wangxb147\AppData\Roaming\npm\node_modules\truffle
> node ./scripts/postinstall.js
Error: Error while attempting to download and cache solc 0.5.8: Command failed: node ./build/cli.bundled.js obtain --solc=0.5.8
    at postinstallObtain (C:\Users\wangxb147\AppData\Roaming\npm\node_modules\truffle\scripts\postinstall.js:13:11)
    at Object.<anonymous> (C:\Users\wangxb147\AppData\Roaming\npm\node_modules\truffle\scripts\postinstall.js:20:3)
    at Module._compile (module.js:635:30)
    at Object.Module._extensions..js (module.js:646:10)
    at Module.load (module.js:554:32)
    at tryModuleLoad (module.js:497:12)
    at Function.Module._load (module.js:489:3)
    at Function.Module.runMain (module.js:676:10)
    at startup (bootstrap_node.js:187:16)
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/94717410
