SpringBoot整合ActiveMQ消息队列
程序员-上善若水 发表于 2022/06/24 22:18:04 2022/06/24
【摘要】 SpringBoot ActiveMQ ActiveMQpom.xmlapplication.propertiesActiveMQConfig.java(发布订阅)消息提供者ProducerSer...
ActiveMQ
Apache ActiveMQ是Apache软件基金会所研发的开放源代码消息中间件;由于ActiveMQ是一个纯Java程序,因此只需要操作系统支持Java虚拟机,ActiveMQ便可执行。
下面是SpringBoot 集成ActiveMQ实现点对点以及发布订阅。
pom.xml
 <!--        activemq-->
        <dependency>
            <artifactId>spring-boot-starter-activemq</artifactId>
        </dependency>
        <!--        <dependency>-->
        <!--            <groupId>org.apache.activemq</groupId>-->
        <!--            <artifactId>activemq-pool</artifactId>-->
        <!--        </dependency>-->
        <dependency>
            <groupId>org.messaginghub</groupId>
            <artifactId>pooled-jms</artifactId>
            <version>1.0.3</version>
        </dependency>
#activemq
queueName=common.queue
topicName=video.topic
spring.activemq.broker-url=tcp://localhost:61616
#集群配置
#spring.activemq.broker-url=failover:(tcp://localhost:61616,tcp://localhost:61617)
spring.activemq.user=admin
spring.activemq.password=admin
spring.activemq.pool.enabled=true
spring.activemq.pool.max-connections=100
@Configuration
@SuppressWarnings({"all"})
public class ActiveMQConfig {
    @Value("${queueName}")
    private String queueName;
    @Value("${topicName}")
    private String topicName;
    @Bean
    public Queue queue(){
        return new ActiveMQQueue(queueName);
    @Bean
    public Topic topic(){
        return new ActiveMQTopic(topicName);
    @Bean
    public JmsListenerContainerFactory<?> jmsListenerContainerTopic(ConnectionFactory activeMQConnectionFactory) {
        DefaultJmsListenerContainerFactory bean = new DefaultJmsListenerContainerFactory();
        bean.setPubSubDomain(true);
        bean.setConnectionFactory(activeMQConnectionFactory);
        return bean;
消息提供者ProducerService.java
public interface ProducerService {
	public boolean sendMessage(Destination destination,String message);
	public boolean sendMessage(String message);
	public boolean publish(String msg);
ProducerServiceImpl.java
@Service
public class ProducerServiceImpl implements ProducerService {
	@Autowired
	private Queue queue;
	@Autowired
	private Topic topic;
	@Autowired
	JmsMessagingTemplate jmsMessagingTemplate;
	private Logger logger = LoggerFactory.getLogger(this.getClass());
	@Override
	public boolean sendMessage(Destination destination, String message) {
		try{
			jmsMessagingTemplate.convertAndSend(destination,message);
			return true;
		}catch (Exception e){
			e.printStackTrace();
			logger.info(e.toString());
		return false;
	@Override
	public boolean sendMessage(String message) {
		try {
			jmsMessagingTemplate.convertAndSend(queue,message);
			return true;
		return false;
	@Override
	public boolean publish(String msg) {
		try{
			jmsMessagingTemplate.convertAndSend(topic,msg);
			return true;
		return false;
消息接收者
点对点
@JmsListener(destination="common.queue")
	public void receiveQueue(String text){
		System.out.println("CommonConsumer收到的报文为:"+text);
@JmsListener(destination="order.queue")
		System.out.println("OrderConsumer收到的报文为:"+text);
订阅
	@JmsListener(destination="video.topic", containerFactory="jmsListenerContainerTopic",id = "1")
	public void receive1(String text){
		System.out.println("video.topic 消费者:receive1="+text);
	@JmsListener(destination="video.topic", containerFactory="jmsListenerContainerTopic",id = "3")
	public void receive2(String text){
		System.out.println("video.topic 消费者:receive2="+text);
	@JmsListener(destination="video.topic", containerFactory="jmsListenerContainerTopic",id = "2")
	public void receive3(String text){
		System.out.println("video.topic 消费者:receive3="+text);
启动类
@EnableJms
测试ActiveController
@RestController
@RequestMapping("/avtivemq")
public class ActiveController {
	@Autowired
	private ProducerService producerService;
	@GetMapping("/AddMq")
	public String AddMq(){
		Destination destination = new ActiveMQQueue("commue.abc");
		boolean result = producerService.sendMessage(destination,"你哈啊");
		if (!result){
			return "fail";
		return "success";
	@GetMapping("/AddMqComm")
	public String AddMqComm(){
		boolean result =producerService.sendMessage("你哈啊Comm");
		if (!result){
			return "fail";
		return "success";
	@GetMapping("/AddMqAll")
	public String AddMqAll(){
		boolean result =producerService.publish("你哈啊Comm");
		if (!result){
			return "fail";
		return "success";
文章来源: blog.csdn.net,作者:小毕超,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_43692950/article/details/107442701
