unity之模糊背景(带你欣赏女人的朦胧美)
爱上游戏开发 发表于 2022/06/24 18:07:46 2022/06/24
【摘要】 最近项目用到了模糊背景效果。实现方法为:shader。代码来自百度。接下来给大家介绍一下模糊背景的实现过程。首先你需要一个先人已经写好的shader(当然,如果你有能力,也可以自己实现!)没有的可以通过以下链接下载材质球和对应的shader。模糊背景shader模糊背景材质球shader如下:Shader "FT/Blur/Back"{ Properties { _Color ("Main...
模糊背景shader
模糊背景材质球
shader如下:
	Properties
		_Color ("Main Color", Color) = (1,1,1,1)
        _Size ("Size", Range(0, 20)) = 1
	Category {
        // We must be transparent, so other objects are drawn before this one.
        Tags {
			"Queue"="Transparent"
			"IgnoreProjector"="True"
			"RenderType"="Transparent"
			"PreviewType" = "Plane"
			"CanUseSpriteAtlas" = "True"
        SubShader {
            // Horizontal blur
            GrabPass
                Tags { "LightMode" = "Always" }
            Pass {
                Name "BackBlurHor"
                CGPROGRAM
                #pragma vertex vert
                #pragma fragment frag
                #pragma fragmentoption ARB_precision_hint_fastest
                #include "UnityCG.cginc"
                struct appdata_t {
                    float4 vertex : POSITION;
                    float2 texcoord : TEXCOORD0;
					float4 color    : COLOR;
                struct v2f {
                    float4 uvgrab : TEXCOORD0;
                v2f vert (appdata_t v) {
                    v2f o;
                    o.vertex = UnityObjectToClipPos(v.vertex);
                    #if UNITY_UV_STARTS_AT_TOP
                    float scale = -1.0;
                    #else
                    float scale = 1.0;
                    #endif
                    o.uvgrab.xy = (float2(o.vertex.x, o.vertex.y*scale) + o.vertex.w) * 0.5;
                    o.uvgrab.zw = o.vertex.zw;
					o.color = v.color;
                    return o;
                sampler2D _GrabTexture;
                float4 _GrabTexture_TexelSize;
			    float4 _MainTex_TexelSize;
                float _Size;
                uniform float4 _Color;
                half4 GrabPixel(v2f i, float weight, float kernel){
                    kernel = sign(sign(abs(i.uvgrab.x)) + sign(abs(i.uvgrab.y))) * kernel;
					return tex2Dproj(_GrabTexture, UNITY_PROJ_COORD(float4(i.uvgrab.x + _GrabTexture_TexelSize.x * kernel * _Size, i.uvgrab.y, i.uvgrab.z, i.uvgrab.w))) * weight;
                half4 frag( v2f i ) : COLOR {
                 	half4 sum = half4(0,0,0,0);
                    sum += GrabPixel(i, 0.05, -4.0);
                    sum += GrabPixel(i, 0.09, -3.0);
                    sum += GrabPixel(i, 0.12, -2.0);
                    sum += GrabPixel(i, 0.15, -1.0);
                    sum += GrabPixel(i, 0.18,  0.0);
                    sum += GrabPixel(i, 0.15, +1.0);
                    sum += GrabPixel(i, 0.12, +2.0);
                    sum += GrabPixel(i, 0.09, +3.0);
                    sum += GrabPixel(i, 0.05, +4.0);
                    float4 col5 = tex2Dproj(_GrabTexture, UNITY_PROJ_COORD(i.uvgrab));
					fixed decayFactor = sign(sign(abs(i.uvgrab.x)) + sign(abs(i.uvgrab.y)));
					sum = lerp(col5, sum, decayFactor) * i.color * _Color;
                    return sum;
                ENDCG
            // Vertical blur
            GrabPass {
            Pass {
                Name "BackBlurVer"
                CGPROGRAM
                #pragma vertex vert
                struct appdata_t {
                    float2 texcoord: TEXCOORD0;
                struct v2f {
                    v2f o;
                    float scale = -1.0;
                    #else
                    float scale = 1.0;
                    #endif
					o.color = v.color;
                    return o;
                float _Size;
                    return tex2Dproj( _GrabTexture, UNITY_PROJ_COORD(float4(i.uvgrab.x, i.uvgrab.y + _GrabTexture_TexelSize.y * kernel * _Size, i.uvgrab.z, i.uvgrab.w))) * weight;
                    return sum;
                ENDCG
unity中使用方法:
为工程导入下载的材质球和shader
通常我们新建Material文件夹存放材质球
创建Shader文件夹存放shader代码
新建背景Image,命名为bg,并为其赋上指定的图片资源,如下:
新建模糊材质背景Image,命名为mask,SourceImage指定任意值即可;Material指定下载的材质球
效果如下:
调节材质球的Size可以调节模糊程度。值越大,效果越模糊。
将size值拉到5效果如下:
