Oracle错误汇总:
隔壁老汪 发表于 2022/06/24 00:35:58 2022/06/24
【摘要】 [color=red]1.[/color]ERROR: HHH000319: Could not get database metadata java.sql.SQLException: Listener refused the connection with the following error: ORA-12505, TNS:li...
 <!--MySql 驱动程序 eg. mysql-connector-java-5.0.4-bin.jar-->  <property name="dialect">org.hibernate.dialect.MySQLDialect</property>  <property name="connection.driver_class">com.mysql.jdbc.Driver</property>  <!-- JDBC URL -->  <property name="connection.url">jdbc:mysql://localhost/dbname?characterEncoding=gb2312</property>  <!-- 数据库用户名-->  <property name="connection.username">root</property>  <!-- 数据库密码-->  <property name="connection.password">root</property>  <!--Sql Server 驱动程序 eg. jtds-1.2.jar-->  <property name="dialect">org.hibernate.dialect.SQLServerDialect</property>  <property name="connection.driver_class">net.sourceforge.jtds.jdbc.Driver</property>  <!-- JDBC URL -->  <property name="connection.url">jdbc:jtds:sqlserver://localhost:1433;DatabaseName=dbname</property>  <!-- 数据库用户名-->  <property name="connection.username">sa</property>  <!-- 数据库密码-->  <property name="connection.password"></property>  <!--Oracle 驱动程序 ojdbc14.jar-->  <property name="dialect">org.hibernate.dialect.OracleDialect</property>  <property name="connection.driver_class">oracle.jdbc.driver.OracleDriver</property>  <!-- JDBC URL -->  <property name="connection.url">jdbc:oracle:thin:@localhost:1521:dbname</property>  <!-- 数据库用户名-->  <property name="connection.username">test</property>  <!-- 数据库密码-->  <property name="connection.password">test</property>
RDBMS	方言DB2	org.hibernate.dialect.DB2DialectDB2 AS/400	org.hibernate.dialect.DB2400DialectDB2 OS390	org.hibernate.dialect.DB2390DialectPostgreSQL	org.hibernate.dialect.PostgreSQLDialectMySQL	org.hibernate.dialect.MySQLDialectMySQL with InnoDB	org.hibernate.dialect.MySQLInnoDBDialectMySQL with MyISAM	org.hibernate.dialect.MySQLMyISAMDialectOracle (any version)	org.hibernate.dialect.OracleDialectOracle 9i/10g	org.hibernate.dialect.Oracle9DialectSybase	org.hibernate.dialect.SybaseDialectSybase Anywhere	org.hibernate.dialect.SybaseAnywhereDialectMicrosoft SQL Server	org.hibernate.dialect.SQLServerDialectSAP DB	org.hibernate.dialect.SAPDBDialectInformix	org.hibernate.dialect.InformixDialectHypersonicSQL	org.hibernate.dialect.HSQLDialectIngres	org.hibernate.dialect.IngresDialectProgress	org.hibernate.dialect.ProgressDialectMckoi SQL	org.hibernate.dialect.MckoiDialectInterbase	org.hibernate.dialect.InterbaseDialectPointbase	org.hibernate.dialect.PointbaseDialectFrontBase	org.hibernate.dialect.FrontbaseDialectFirebird	org.hibernate.dialect.FirebirdDialect
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/84382450
