微服务架构-windows vagrant虚拟环境搭建
隔壁老汪 发表于 2022/06/23 23:53:15 2022/06/23
【摘要】 在windows下利用vagrant运行mesos环境 1、下载virtual box; 2、下载vagrant 3、下载box镜像 4、本地添加镜像 F:\Vagrant\mesos>vagrant box add "centos/7" centos-7.0-x86_64.box==> box: Box file...
1、下载virtual box;
2、下载vagrant
3、下载box镜像
4、本地添加镜像
  1. F:\Vagrant\mesos>vagrant box add "centos/7" centos-7.0-x86_64.box
  2. ==> box: Box file was not detected as metadata. Adding it directly...
  3. ==> box: Adding box 'centos/7' (v0) for provider:
  4. box: Unpacking necessary files from: file://F:/Vagrant/mesos/centos-7.0-x86_64.box
  5. box: Progress: 100% (Rate: 12.9M/s, Estimated time remaining: --:--:--)
  6. ==> box: Successfully added box 'centos/7' (v0) for 'virtualbox'!
5、vagrant up 启动
  1. Failed to locate the powershell executable on the available PATH. Please
  2. ensure powershell is installed and available on the local PATH, then
  3. run the command again.
在环境变量中配置powerShell
版本不对需要升级3.0
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/81705546
