springboot项目中集成ip2region包 FileNotFoundException
隔壁老汪 发表于 2022/06/23 23:34:57 2022/06/23
【摘要】 05:15:55.344 sms [asyncTaskExecutor-1] ERROR cc.mrbird.common.util.AddressUtils 54 - 获取地址信息异常:{}java.io.FileNotFoundException: class path resource [ip2region/ip2region.d...
  1. 05:15:55.344 sms [asyncTaskExecutor-1] ERROR cc.mrbird.common.util.AddressUtils 54 - 获取地址信息异常:{}
  2. java.io.FileNotFoundException: class path resource [ip2region/ip2region.db] cannot be resolved to absolute file path because it does not reside in the file system: jar:file:/app.jar!/BOOT-INF/classes!/ip2region/ip2region.db
  3. at org.springframework.util.ResourceUtils.getFile(ResourceUtils.java:217)
  4. at org.springframework.core.io.AbstractFileResolvingResource.getFile(AbstractFileResolvingResource.java:133)
  5. at cc.mrbird.common.util.AddressUtils.getCityInfo(AddressUtils.java:25)
  6. at cc.mrbird.system.service.impl.LogServiceImpl.saveLog(LogServiceImpl.java:94)
  7. at cc.mrbird.system.service.impl.LogServiceImpl$$FastClassBySpringCGLIB$$f6e62249.invoke(<generated>)
  8. at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
  9. at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:746)
  10. at org.sp
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/82800068
