SpringBoot的yaml配置文件,提示Do not use @ for indentation
隔壁老汪 发表于 2022/06/24 01:42:59 2022/06/24
【摘要】 spring boot应用启动时,报不要使用@符号的错误: … Caused by: org.yaml.snakeyaml.scanner.ScannerException: while scanning for the next token found character ‘@’ that cannot start any toke...
found character ‘@’ that cannot start any token. (Do not use @ for indentation)
in ‘reader’, line 2, column 11:
@oldLocalSendDir@
可以使用双引号将其引用起来,改为 “@oldLocalSendDir@”。
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/86715988
