Error: Cannot perform an interactive login from a non TTY device
隔壁老汪 发表于 2022/06/24 01:22:10 2022/06/24
【摘要】 Docker on Windows: interactive tty session gives “cannot enable tty mode on non tty input” Trying to run a shell into a running container (docker exec -it containerid b...
Trying to run a shell into a running container (docker exec -it containerid bash) using DockerToolbox/docker-machine on Windows 7 gives this error:
"cannot enable tty mode on non tty input"
(this runs fine on Mac OS X)
This is logged as an issue here. As a workaround, prefix the docker command with winpty, so:
winpty docker exec -it containerid bash
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/84138755
