Win10下安装docker toolbox 及使用 坑太多 都在这
【摘要】
到官网下载boot
https://download.docker.com/win/stable/DockerToolbox.exe
安装完成后点击启动
dockermachine配置
wangxb147@wangxb MINGW64 ~$ docker-machine ssh defaultmachine ...
到官网下载boot
安装完成后点击启动
dockermachine配置
machine does not exist
$ docker run
"docker run" requires at least 1 argument.
See 'docker run --help'.
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG...] [flags]
Run a command in a new container
$ docker-machine ls
NAME ACTIVE DRIVER STATE URL SWARM DOCKER ERRORS
default - virtualbox Error Unknown machine does not exist
$ docker-machine env default
Error checking TLS connection: machine does not exist
wangxb147@wangxb
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/84324309
cloudbbs@huaweicloud.com
