Nginx配置https, 80端口重定向443
隔壁老汪 发表于 2022/06/24 01:19:03 2022/06/24
【摘要】     server { listen 443 ssl; server_name www.r.cn; charset utf-8; access_log /var/log/nginx/www/access.log; add_header X-Xss-Protectio...
  1. server {
  2. listen 443 ssl;
  3. server_name www.r.cn;
  4. charset utf-8;
  5. access_log /var/log/nginx/www/access.log;
  6. add_header X-Xss-Protection 1;
  7. ssl_certificate /etc/nginx/cert/证书.pem;
  8. ssl_certificate_key /etc/nginx/cert/证书.key;
  9. location / {
  10. try_files /_not_exists_ @backend;
  11. }
  12. location @backend {
  13. proxy_set_header X-Forwarded-For $remote_addr;
  14. proxy_set_header Host $http_host;
  15. proxy_set_header X-Forwarded-Proto $scheme;
  16. }
  17. }
  18. server {
  19. listen 80;
  20. server_name 域名;
  21. rewrite ^(.*)$ https://${server_name}$1 permanent;
  22. }
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/105142386
