SpringBoot入门到精通- 基于filter正则实现 AJAX跨域CorsFilter
隔壁老汪 发表于 2022/06/23 23:05:17 2022/06/23
【摘要】 设置配置问题 cors.allowedOrigins= http://localhost:4200, https://.*subdomain\\.domain\\.com 基于filter import org.springframework.beans.factory.annotation.Value;import org.sp...
设置配置问题
基于filter
  1. import org.springframework.beans.factory.annotation.Value;
  2. import org.springframework.stereotype.Component;
  3. import javax.servlet.*;
  4. import javax.servlet.http.HttpServletRequest;
  5. import javax.servlet.http.HttpServletResponse;
  6. import java.io.IOException;
  7. import java.util.ArrayList;
  8. import java.util.List;
  9. import java.util.regex.Matcher;
  10. import java.util.regex.Pattern;
  11. @Component
  12. public class CORSFilter implements Filter {
  13. @Value("${cors.allowedOrigins}")
  14. private String[] allowedOrigins;
  15. @Override
  16. public void doFilter(ServletRequest request, ServletResponse response, FilterChain chain)
  17. throws IOException, ServletException {
  18. HttpServletRequest req = (HttpServletRequest) request;
  19. String requestOrigin = req.getHeader("Origin");
  20. List<Pattern> allowedOriginsRegex &#
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/109208804
