JAVA入门到精通-fastJSON判断多层嵌套JSON数据中是否包含特定key
隔壁老汪 发表于 2022/06/24 01:14:45 2022/06/24
【摘要】 判断多层嵌套JSON数据中是否包含特定key 获取复杂json 某个指定key的值 添加依赖:       <dependency>           &nbs...
获取复杂json 某个指定key的值
添加依赖:
      <dependency>
            <groupId>com.jayway.jsonpath</groupId>
            <artifactId>json-path</artifactId>
            <version>2.4.0</version>
        </dependency>
github: https://github.com/json-path/JsonPath
代码demo:
JSONObject dataJson = new JSONObject();
dataJson.put("a", "123");
JSONObject aJson = new JSONObject();
aJson.put("b", "456123213123");
dataJson.put("c", aJson);
System.out.println(JsonPath.read(dataJson.toJSONString(), "@.c.b"));
  1. public static void main(String[] args){
  2. String jsonStr ="{\"properties\":{\"user_utt\":{\"fielddata\":\"111\",\"analyzer\":\"ngram_analyzer\",\"term_vector\":\"yes\",\"type\":\"text\"},\"user_utt_lemma_yomi\":{\"fielddata\":\"true\",\"analyzer\":\"whitespace\",\"term_vector\":\"yes\",\"type\":\"text\"},\"ui_reserve2\":{\"index\":\"not_analyzed\",\"type\":\"keyword\",\"type1\":\"keyword\"},\"ui_reserve1\":{\"index\":\"not_analyzed\",\"type\":\"keyword\"},\"add_utt\":{\"index\":\"not_analyzed\",\"type\":\"keyword\"},\"topic\":{\"index\":\"not_analyzed\",\"type\":\"keyword\"},\"current_status\":{\"index\":\"not_analyzed\",\"type\":\"integer\"},\"original_user_utt\":{\"index\":\"not_analyzed\",\"type\":\"keyword\"},\"user_utt_length\":{\"index\":\"not_analyzed\",\"type\":\"long\"},\"user_utt_lemma\":{\"fielddata\":\"true\",\"analyzer\":\"whitespace\",\"term_vector\":\"yes\",\"type\":\"text\"},\"subtopic\":{\"index\":\"not_analyzed\",\"type\":\"keyword\"}}}";
  3. JSONObject jsonObject = JSON.parseObject(jsonStr);
  4. JSONObject dataJson = new JSONObject();
  5. dataJson.put("a", "123");
  6. JSONObject aJson = new JSONObject();
  7. aJson.put("b", "456123213123");
  8. dataJson.put("c", aJson);
  9. Object object = JsonPath.read(dataJson.toJSONString(), "*.b");
  10. System.out.println(dataJson.toJSONString());
  11. System.out.println(object);
  12. Object object2 = JsonPath.read(jsonStr, ".type");
  13. System.out.println(object2);
  14. System.out.println("key:" + getKeyFormJson(jsonObject,"analyzer"));
  15. }
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/106015754
