Nginx 四层代理配置模板
隔壁老汪 发表于 2022/06/24 01:22:01 2022/06/24
【摘要】 worker_processes 4;worker_rlimit_nofile 40000; events { worker_connections 8192;} http { upstream rancher { server IP_NODE_1:80; server IP_NODE_2:80;...
  1. worker_processes 4;
  2. worker_rlimit_nofile 40000;
  3. events {
  4. worker_connections 8192;
  5. }
  6. http {
  7. upstream rancher {
  8. server IP_NODE_1:80;
  9. server IP_NODE_2:80;
  10. server IP_NODE_3:80;
  11. }
  12. map $http_upgrade $connection_upgrade {
  13. default Upgrade;
  14. '' close;
  15. }
  16. server {
  17. listen 443 ssl http2;
  18. server_name FQDN;
  19. ssl_certificate /certs/fullchain.pem;
  20. ssl_certificate_key /certs/privkey.pem;
  21. location / {
  22. proxy_set_header Host $host;
  23. proxy_set_header X-Forwarded-Proto $scheme;
  24. proxy_set_header X-Forwarded-Port $server_port;
  25. proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
  26. proxy_pass http://rancher;
  27. proxy_http_version 1.1;
  28. proxy_set_header Upgrade $http_upgrade;
  29. proxy_set_header Connection $connection_upgrade;
  30. # This allows the ability for the execute shell windo
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/124970478
