Mysql从入门到精通-查询数据库中表大小
隔壁老汪 发表于 2022/06/24 01:32:43 2022/06/24
【摘要】 select table_name, data_length from information_schema.tables where table_schema='DBNAME'; SELECT table_name,  sum(DATA_LENGTH)+sum(INDEX_LENGTH) FROM informati...
FROM information_schema.TABLES where TABLE_SCHEMA='DBNAME' GROUP BY TABLE_NAME;
结果除以 1024*1024 为 M
改进一下
select table_name, data_length/(1024*1024) from information_schema.tables where table_schema='saku';
SELECT table_name,  (sum(DATA_LENGTH)+sum(INDEX_LENGTH))/(1024*1024)
FROM information_schema.TABLES where TABLE_SCHEMA='saku' GROUP BY TABLE_NAME;
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/106093200
