SpringBoot从入门到精通-Dozer vs MapStruct 比较
隔壁老汪 发表于 2022/06/23 23:50:07 2022/06/23
【摘要】   Mapping Dozer vs MapStruct POSTED BY MARIUSZ WYSZOMIERSKI In multi-tier applications there is often a need for mapping between two data models. In this ...
In multi-tier applications there is often a need for mapping between two data models. In this article you can read about comparing two mapping libraries:
The most common use case is coping data from entity objects to DTO objects usually used in service REST/SOAP.
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/106186861
