SpringBoot遍历Lib读取引用jar包列表
隔壁老汪 发表于 2022/06/23 23:41:20 2022/06/23
【摘要】 URL url = InternationalResouces.class.getProtectionDomain().getCodeSource().getLocation(); JarFile jarFile = new JarFile(url.getFile()); Enumeration<JarEntry> enum...
Enumeration<JarEntry> enumeration = jarFile.entries();
while (enumeration.hasMoreElements()) {
    JarEntry entry = enumeration.nextElement();
    String entryName = entry.getName();
    if (entryName.indexOf(path) != -1 && entryName.endsWith("properties")) {
        String[] pathGroup = entryName.split("/");
        String fileName = pathGroup[pathGroup.length - 1];
        String[] nameGroup = fileName.split("\\.");
        if (nameGroup.length != 2) {
            continue;
        String realName = nameGroup[0];
        String[] realNameGroup = realName.split("_");
        if (realNameGroup.length != 2) {
            continue;
        String country = realNameGroup[1];
        Properties properties = new Properties();
        properties.load(jarFile.getInputStream(entry));
        LanguageStore store = new LanguageStore();
        store.setCountry(country);
        store.setLanguageMap(properties);
        languageStore.add(store);
jarFile.close();
文章来源: blog.csdn.net,作者:隔壁老瓦,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/wxb880114/article/details/122920700
