SpringBoot2.2.X及2.3.X 集成 SpringCloud
程序员-上善若水 发表于 2022/06/24 00:35:04 2022/06/24
【摘要】 SpringBoot2.2.X及2.3.X 集成 SpringCloud 一、pom <!-- spring cloud eureka 注册中心--> <dependency>...
一、pom
<dependency>
    <groupId>org.springframework.cloud</groupId>
    <artifactId>spring-cloud-starter-netflix-eureka-server</artifactId>
</dependency>
<!--hystrix断路器-->
<dependency>
    <groupId>com.netflix.hystrix</groupId>
    <artifactId>hystrix-javanica</artifactId>
    <version>RELEASE</version>
</dependency>
<dependency>
    <artifactId>hystrix-core</artifactId>
</dependency>
<dependencyManagement>
    <dependencies>
        <dependency>
            <artifactId>spring-cloud-dependencies</artifactId>
            <version>Hoxton.SR1</version>
            <type>pom</type>
            <scope>import</scope>
        </dependency>
    </dependencies>
</dependencyManagement>
二、注册中心配置application.properties
#springCloud 注册中心配置
eureka.instance.hostname=localhost
eureka.client.registerWithEureka=false
eureka.client.fetchRegistry=false
eureka.client.serviceUrl.defaultZone=http://${eureka.instance.hostname}:${server.port}/eureka/
三、客户端配置application.properties
#springCloud 注册客户端配置
eureka.client.serviceUrl.defaultZone = http://localhost:8761/eureka/
spring.application.name = FrameServer
四、调用远程接口
ResConfig
@Configuration
@Component
public class ResConfig {
    @Bean
    @LoadBalanced
    RestTemplate restTemplate() {
        return new RestTemplate();
五、Service
public interface RpcService {
    DetectionInfo FaceInfoDatection(String base64);
六、impl
@Service
public class RpcServiceImpl implements RpcService {
    @Autowired
    private RestTemplate restTemplate;
    @Autowired
    Gson gson;
    @Override
    public DetectionInfo FaceInfoDatection(String base64) {
        String data = GetFaceInfo(base64);
        if (data != null || !data.equals("err")){
            DetectionInfo detectionInfo = gson.fromJson(data,DetectionInfo.class);
            return detectionInfo;
        return null;
    @HystrixCommand(fallbackMethod = "error")
    public String GetFaceInfo(String base64){
        MultiValueMap<String, String> map= new LinkedMultiValueMap<String, String>();
        map.add("base64Str",base64);
        HttpHeaders headers = new HttpHeaders();
        headers.setContentType(MediaType.APPLICATION_FORM_URLENCODED);
        HttpEntity<MultiValueMap<String, String>> request = new HttpEntity<MultiValueMap<String, String>>(map, headers);
        return restTemplate.postForObject("http://AISERVER/FaceInfoDatection",request,String.class);
        return null;
    public String error(String name){
        return "err";
    public String error(){
        return "err";
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
七、启动类
//@EnableEurekaClient 开启客户端
//@EnableEurekaServer 开启注册中心
//@EnableHystrix 开启断路器
文章来源: blog.csdn.net,作者:小毕超,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_43692950/article/details/107443824
