【Go语言实战】 (15) Gin+gRPC 微服务实现备忘录 (下) | 备忘录模块
小生凡一 发表于 2022/06/20 00:58:49 2022/06/20
【摘要】 文章目录 写在前面源码地址:1. 备忘录部分1.1 proto模块定义1.2 数据库结构定义1.3 接入ETCD 2. 网关接入2.1 服务接入2.2 controller 3. 测试返回...
写在前面
和上篇文章类似,这次我们完成具体功能部分。
源码地址:
https://github.com/CocaineCong/gRPC-todoList
1. 备忘录部分
1.1 proto模块定义
taskModel.proto
syntax="proto3";
package pb;
option go_package = "/internal/service;service";
message TaskModel {
    // @inject_tag: json:"favorite_id"
    uint32 TaskID=1;
    // @inject_tag: json:"user_id"
    uint32 UserID=2;
    // @inject_tag: json:"status"
    uint32 Status=3;
    // @inject_tag: json:"title"
    string Title=4;
    // @inject_tag: json:"content"
    string Content=5;
    // @inject_tag: json:"start_time"
    uint32 StartTime=6;
    // @inject_tag: json:"end_time"
    uint32 EndTime=7;
taskService.proto
syntax="proto3";
package pb;
import "taskModels.proto";
message TaskRequest{
    uint32 TaskID=1;
    uint32 UserID=2;
    uint32 Status=3;
    string Title=4;
    string Content=5;
    uint32 StartTime=6;
    uint32 EndTime=7;
message TasksDetailResponse{
  repeated TaskModel TaskDetail=1;
  uint32 Code=2;
message CommonResponse{
    uint32 Code=1;
    string Msg=2;
    string Data=3;
service TaskService{
  rpc TaskCreate(TaskRequest) returns(CommonResponse);
  rpc TaskUpdate(TaskRequest) returns(CommonResponse);
  rpc TaskShow(TaskRequest) returns(TasksDetailResponse);
  rpc TaskDelete(TaskRequest) returns(CommonResponse);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
获取所有生成pb.go文件
protoc -I internal/service/pb internal/service/pb/*.proto --go_out=plugins=grpc:.
1.2 数据库结构定义
  • 模型定义
type Task struct {
	TaskID    uint   `gorm:"primarykey"` // 收藏夹id
	UserID    uint   `gorm:"index"`      // 用户id
	Status    int    `gorm:"default:0"`
	Title 	  string
	Content   string `gorm:"type:longtext"`
	StartTime int64
	EndTime   int64
  • 展示所有的任务
func (*Task) Show (req *service.TaskRequest)(taskList []Task,err error) {
	err = DB.Model(Task{}).Where("user_id=?", req.UserID).Find(&taskList).Error
	if err != nil {
		return taskList, err
	return taskList, nil
  • 创建备忘录
func (*Task) Create (req *service.TaskRequest) error {
	task := Task{
		UserID: uint(req.UserID),
		Title : req.Title,
		Content : req.Content,
		Status : int(req.Status),
		StartTime : int64(req.StartTime),
		EndTime : int64(req.EndTime),
	if err := DB.Create(&task).Error; err != nil {
		util.LogrusObj.Error("Insert Task Error:" + err.Error())
		return err
	return nil
  • 删除备忘录
func (*Task) Delete(req *service.TaskRequest) error {
	err := DB.Where("task_id=?", req.TaskID).Delete(Task{}).Error
	return err
  • 更新
func (*Task) Update(req *service.TaskRequest) error {
	t := Task{}
	err := DB.Where("task_id=?", req.TaskID).First(&t).Error
	if err != nil {
		return err
	t.Title = req.Title
	t.Content = req.Content
	t.Status = int(req.Status)
	t.StartTime = int64(req.StartTime)
	t.EndTime = int64(req.EndTime)
	err = DB.Save(&t).Error
	return err
1.3 接入ETCD
  • ETCD服务初始化
etcdAddress := []string{viper.GetString("etcd.address")}
etcdRegister := discovery.NewRegister(etcdAddress, logrus.New())
grpcAddress := viper.GetString("server.grpcAddress")
  • 节点接入ETCD
taskNode := discovery.Server{
	Addr: grpcAddress,
server := grpc.NewServer()
  • 服务注册节点
service.RegisterTaskServiceServer(server, handler.NewTaskService())
lis, err := net.Listen("tcp", grpcAddress)
if err != nil {
	panic(err)
if _, err := etcdRegister.Register(taskNode, 10); err != nil {
	panic(fmt.Sprintf("start server failed, err: %v", err))
2. 网关接入
2.1 服务接入
  • 获取ETCD的服务
taskConn, _ := grpc.Dial("127.0.0.1:10002", opts...)
taskService := service.NewTaskServiceClient(taskConn)
  • 路由注入
authed := v1.Group("/")
authed.Use(middleware.JWT())
	// 任务模块
	authed.GET("task", handler.GetTaskList)
	authed.POST("task", handler.CreateTask)
	authed.PUT("task", handler.UpdateTask)
	authed.DELETE("task", handler.DeleteTask)
将服务存放在gin.Keys中
func InitMiddleware(service []interface{}) gin.HandlerFunc {
	return func(context *gin.Context) {
		// 将实例存在gin.Keys中
		context.Keys = make(map[string]interface{})
		context.Keys["user"] = service[0]
		context.Keys["task"] = service[1]
		context.Next()
2.2 controller
  • 获取token,获取是哪个用户
claim, _ := util.ParseToken(ginCtx.GetHeader("Authorization"))
  • 获取task服务
TaskService := ginCtx.Keys["task"].(service.TaskServiceClient)
  • 调用服务
TaskResp, err := TaskService.TaskShow(context.Background(), &fReq)
  • 完整代码
func GetTaskList(ginCtx *gin.Context) {
	var fReq service.TaskRequest
	PanicIfTaskError(ginCtx.Bind(&fReq))
	fReq.UserID = uint32(claim.UserID)
	PanicIfTaskError(err)
	r := res.Response{
		Data:   TaskResp,
		Status: uint(TaskResp.Code),
		Msg:    e.GetMsg(uint(TaskResp.Code)),
	ginCtx.JSON(http.StatusOK, r)
3. 测试返回
文章来源: blog.csdn.net,作者:小生凡一,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_45304503/article/details/125348318
