Team
辰chen 发表于 2022/06/15 23:13:04 2022/06/15
【摘要】 文章目录 一、Team总结 一、Team 本题链接:Team 题目: A. Team time limit per test2 seconds memory limit per te...
文章目录
一、Team
本题链接:Team
题目:
A. Team
memory limit per test256 megabytes
inputstandard input
outputstandard output
One day three best friends Petya, Vasya and Tonya decided to form a team and take part in programming contests. Participants are usually offered several problems during programming contests. Long before the start the friends decided that they will implement a problem if at least two of them are sure about the solution. Otherwise, the friends won’t write the problem’s solution.
This contest offers n problems to the participants. For each problem we know, which friend is sure about the solution. Help the friends find the number of problems for which they will write a solution.
Input
The first input line contains a single integer n (1 ≤ n ≤ 1000) — the number of problems in the contest. Then n lines contain three integers each, each integer is either 0 or 1. If the first number in the line equals 1, then Petya is sure about the problem’s solution, otherwise he isn’t sure. The second number shows Vasya’s view on the solution, the third number shows Tonya’s view. The numbers on the lines are separated by spaces.
Output
Print a single integer — the number of problems the friends will implement on the contest.
Examples
input
3
1 1 0
1 1 1
1 0 0
output
2
input
2
1 0 0
0 1 1
output
1
Note
In the first sample Petya and Vasya are sure that they know how to solve the first problem and all three of them know how to solve the second problem. That means that they will write solutions for these problems. Only Petya is sure about the solution for the third problem, but that isn’t enough, so the friends won’t take it.
In the second sample the friends will only implement the second problem, as Vasya and Tonya are sure about the solution.
本博客给出本题截图:
AC代码
#include <iostream>
using namespace std;
int  main()
	int n, res = 0;
	cin >> n;
	while (n -- )
		int a, b, c;
		cin >> a >> b >> c;
		if ((a + b + c) > 1) res ++;
	cout << res << endl;
	return 0;
题意:两个人都是1则过,否则不过
contest竞赛
participant 参与者
offer 提出
implement 执行
solution 解决方案
水题,不解释
文章来源: chen-ac.blog.csdn.net,作者:辰chen,版权归原作者所有,如需转载,请联系作者。
原文链接:chen-ac.blog.csdn.net/article/details/117235051
