string类的模拟实现
跳动的bit 发表于 2022/06/15 23:02:06 2022/06/15
【摘要】 💦 string类的模拟实现💨 string.h#pragma oncenamespace bit{ public: typedef char* iterator; typedef const char* const_iterator; iterator begin() { return _str; } iterator end() { return _str +...
💦 string类的模拟实现
💨 string.h
#pragma once
namespace bit
	public:
		iterator begin()
			return _str;
		iterator end()
			return _str + _size;
		const_iterator begin() const
			return _str;
		const_iterator end() const
		/*string()
			:_str(new char[1])
			,_size(0)
			,_capacity(0)
			*_str = '\0';
		//string(char* str = "\0")
		string(char* str = "")
			:_size(strlen(str))
			,capacity(_size);
			_str(new char[_capacity + 1]);//预留\0
			strcpy(_str, str);
		//s1.swap(s2)
		void swap(string& s)
			//注意这里的swap不算重载,重载要求的是在同一作用域,就像string和vector里都有push_back,它们函数名、返回值、参数可能都是相同的,那它们俩能同时存在的原因就是它俩在不同的作用域
			::swap(_str, s._str);
			::swap(_size, s._size);
			::swap(_capacity, s._capacity);
		//s2(s1)
		string(const string& s)
			:_str(nullptr);
			string tmp(s._str);
			swap(tmp)//this->swap(tmp);
		//s1=s3
		string& operator=(string s)
			swap(s);//this->swap(s);
			return *this;
		~string()
			delete[] _str;
			_str = nullptr;
		//读写
		char& operator[](size_t pos)
			assert(pos < _size);
			return _str[pos];
		//读
		const char& operator[](size_t pos) const
			return _str[pos];
		//增容
		void reserve(size_t n)
			if(n > _capacity)
				char* tmp = new char[n + 1];
				strcpy(tmp, _str);
				delete[] _str;
				_str = tmp;
				_capacity = n;
		void resize(size_t n, char ch = '\0')
			if(n <= _size)
				_size = n;
				_str[_size] = '\0';
			else
				if(n > _capacity)//一次性增容,避免频繁增容所带来的消耗
					reserve(n);
				for(size_t i = _size; i < n; i++)
					_str[i] = ch;
				_size = n;
				_str[_size] = '\0';
		void push_back(char ch)
			/*if(_size >= _capacity)//扩容
				size_t newcapacity = _capacity == 0 ? 4 : _capacity * 2;
				reserve(newcapacity);
			_str[_size] = ch;
			++_size;
			_str[_size] = '\0';*/
			//实现insert后直接复用
			insert(_size, ch);
		void append(const char* str)
			/*size_t len = strlen(str);
			if(_size + len > _capacity)//扩容
				reserve(_size + len);
			strcpy(_str + _size, str);
			_size += len;*/
			//复用insert
			insert(_size, str);
		string& operator+=(char ch)
			push_back(ch);//this->push_back(ch);
			return *this;
		string& operator+=(const char* str)
			append(str);
			return *this;
		string& operator+=(const string& s)
			*this += s._str;
			return *this;
		size_t size() const
			return _size;
		size_t capacity() const
			return _capacity;
		size_t find(char ch, size_t pos = 0)
			for(size_t i = pos; i < _size; ++i)
				if(_str[i] == ch)
					return i;
			return npos;
		size_t find(const char* sub, size_t pos = 0)
			const char* p = strstr(_str + pos, sub);
			if(p == nullptr)
				return npos;
			else
				return p - _str;
			return npos;
		string& insert(size_t pos, char ch)
			assert(pos <= _size);
			if(_size == _capacity)
			/*int end = _size;
			while(end >= (int)pos)
				_str[end + 1] = _str[end];
				--end;
			size_t end = _size + 1;
			while(end > pos)
				_str[end] = _str[end - 1];
				--end;
			_str[pos] = ch;
			++_size;
			return *this;
		string& insert(size_t pos, const char* str)
			if(len == 0)//空串直接返回
				return *this;
			if(len + _size > _capacity)
				reserve(len + _size);
			size_t end = _size + len;
			while(end >= pos + len)
				_str[end] = str[end - len];
				--end;
			for(size_t i = 0; i < len; ++i)
				_str[pos + i] = str[i];
			_size += len;
			return *this;
		const char* c_str()
			return _str;
		string& erase(size_t pos, size_t len = npos)
			//1、pos后删完
			//2、pos后删一部分
			if(len == npos || pos + len >= _size)
				_str[pos] = '\0';
				_size = pos;
			else
				strcpy(_str + pos, _str + pos + len);//这里直接调用strcpy即可
				_size -= len;
			return *this;
		void print(const string& s)
			for(size_t i = 0; i < s.size(); ++i)
				//s[i] = 'x'//err
				cout << s[i] << " ";
			cout << endl;
			string::const_iterator it = s.begin();
			while(it != s.end())
				cout << *it << " ";
			cout << endl;
		void clear()
			_str[0] = '\0';
			_size = 0;
	private:
		char* _str;
		size_t _size;
		size_t _capacity;//不包含最后做标识的\0
		static const size_t npos;
	static size_t string::npos = -1;
	string operator+(const string& s1, char ch)
		string ret = s1;
		ret += ch;
		return ret;
	string operator+(const string& s1, const char* str)
		string ret = s1;
		ret += str;
		return ret;
	ostream& operator<<(ostream& out, const string& s)
			out << s[i];
		return out;
	istream& operator>>(istream& in, string& s)
		s.clear();
		char ch;
		//in >> ch;
		ch = in.get();
		while(ch != ' ' || ch != '\n')
			s += ch;
			//in >> ch;
			ch = in.get();
		return in;
	istream& getline>>(string& s)
		s.clear();
		char ch;
		ch = in.get();
		while(ch != '\n')
			s += ch;
			ch = in.get();
		return in;
	bool operator>(const string& s1, const string& s2)
		size_t i1 = 0, i2 = 0;
		//“abc" "aa"
		//"aa" "abc"
		while(i1 < s1.size() && i2 < s2.size())
			if(s1[i1] > s2[i2])
				return true;
			else if(s1[i1] < s2[i2])
				return false;
			else
				++i1;
				++i2;
		//"abc" "abc" -> false
		//"abcd" "abc" -> true
		//"abc" "abcd" -> false
		if(i1 == s1.size())
			return false;
		else
			return true;
	bool operator==(const string& s1, const strint& s2)
			if(s1[i1] != s2[i2])
				return false;
			else
				++i1;
				++i2;
		if(i1 == s1.size() && i2 == s2.size())
			return true;
		else
			return false;
	inline bool operator!=(const string& s1, const string& s2)
		return !(s1 == s2);
	inline bool operator>=(const string& s1, const string& s2)
		return s1 > s2 || s1 == s2;
	inline bool operator<(const string& s1, const string& s2)
		return !(s1 >= s2)
	inline bool operator<=(const string& s1, const string& s2)
		return !(s1 > s2)
	void test_string1()
		string s1("hello");
		s1.push_back(' ');
		s1.append("world");
		s1 += ' ';
		s1 += "world";
		string s2(s1);
		s2.resize(3);
		s2.resize(8, 'x');
		s2.resize(20, 'x');
	void test_string2()
		//遍历打印
		//1、
		string s1("hello world");
		for(size_t i = 0; i < s1.size(); ++i)
			s1[i] += 1;//普通迭代器可读写
			cout << s1[i] << " ";
		cout << endl;
		//2、
		string::iterator it = s.begin();
		while(if != s1.end())
			*it -= 1;
			cout << *it << endl;
			++it;
		cout << endl;
		//3、
		for(auto e : s1)
			cout << e << " ";
		cout << endl;
		print(s1);
	void test_string3()
		string s1("hello world"):
		s1.insert(5, 'x');
		cout << s1.c_str() << endl;
		string s2("helloworld");
		s2.insert(5, "bit");
		cout << s2.c_str() << endl;
		s2.insert(0, "hello");
		string s3("helloworld");
		s3.erase(5, 3);
		cout << s3.c_str() << endl;
		s3.erase(5);
	void test_string4()
		string s1("hello");
		cin >> s1;
		cout << s1 << endl;
		//以上两种cout的差别点
		string s2("hello");
		s2.resize(20);
		s2[19] = 'x';
		cout << s1 << endl;
		string s3;
		cin >> s3;
		cout << s3 << endl;
	void test_string5()
		//string s1;
		//cin >> s1;
		//cout << s1 << endl;
		getline(cin, s1);
		cout << s1 << endl;
💨 string.cpp
#include"string.h"
int main()
	try
		bit::test_string1();
		bit::test_string2();
		bit::test_string3();
		bit::test_string4();
		bit::test_string5();
	catch(exception& e)
		cout << e.what() << endl;
	return 0;
📝说明
对于默认构造函数,我们之前说过写无参的不如写全缺省的,这里的缺省值可以给 “” 或 “\0”。_str 需要支持增删查改,所以得把原来的空间拷贝到新开的一块空间上进行操作,需要注意的是 _capacity 不包含 \0,也就是说 10 个字符需要有 11 个空间。
对于普通数组而言,越界读一般是检查不出来的,越界写是抽查,可能会检查出来,可能的意思是数组后面有一个标志位,如果修改了它就会报错,但不可能数组之后都是标志位,所以就可能就会出现往后越界一个位置会报错,往后越界二个位置不会报错的情况。这个在之前有说过,感兴趣的可以去测试下。 但是在 string 里无论是越界读还是越界写都会报错。
为什么到了 string,[ ] 就查的这么严 ???因为 [ ] 是一个函数调用,它对这里的参数进行了严格的检查。
当 _capacity 满了,push_back 直接扩二倍是可以的,但是 append 扩二倍不一定能满足,因为 append 尾插的是一个字符串。
对于 resize,string 里有两个版本,第一个版本如果没给值,它默认是用 \0 初始化,第二个版本是用指定字符初始化。其实第一个版本有点累赘了,这里我们直接把第二个版本的第二个参数设为缺省值为 \0 即可,其中我们在实现 resize 时又分为几种情况:
💨 hello\0:_size = 5
  1. n <= _size:_size = 3
  2. n > _size && n < _capacity:_size = 8
  3. n > _capacity:_size = 15
对于第 3 种,我们也有很多种方法实现,比如去循环复用 +=,当 n 远大于当前空间时效率就很低,可能只需要一步到位的代码,却需要频繁增容,如果你不知道 string 的底层你根本不知道要这样写。这也就是我们为什么要去模拟实现 string 的原因。
对于第 2、3 种,我们的循环里的结束条件不能为 i <= n,因为这里要分情况,如果没传 ch,这里写 i <= n 是没问题的,但是如果传的是 x,就不行了,需要在循环后面补 \0,所以干脆 i < n,再在循环后被 \0。
可以看到迭代器的实现并不难,其实相比 string 和 vector 的迭代器,list 的迭代器就要复杂许多了。string::iterator 就是告诉编译器 iterator 去全局去找是找不到的,要到 string 这个域里去找,迭代器它是一个内嵌类型,所以说它要指定类域。注意这里是一个左闭右开的区间,它是一个普通迭代器,支持读写。
可以看到我们也没实现范围 for,为什么它依然可以完成呢,其实范围 for 的原理就是被替换成迭代器,范围 for 的语法是说取 s1 里的每个数据,赋值给 e,然后它会自动走,自动判断结束。所谓的这些自动其实没这么神奇,就像模板好像很牛逼,写一个 swap,其它地方都可以用,其实是把一些工作交给编译器去做了。这里也是一样,你可以认为这里的 e 是定义的一个变量,然后把 *it 赋值给 e,所以对 e 的改变不会影响 s1,需要加上引用才行。所以范围 for 的原理就是被替换成迭代器。
当然空口无凭,这里我们把 begin 改成了 Begin,报错了,以上就能说明范围 for 会被原模原样的替换成迭代器,但是迭代器得跟着规范去走,得用 begin。
print 就会用到 const 迭代器,对于 const 对象还要去实现一个 const 版本的 operator[],迭代器也要去实现 const 迭代器。注意对于普通对象和 const 对象,operator[] 和迭代器就必须实现两份,而像 size() 实现一份 const 版本就可以满足了。
注意这里实现的 insert 有问题,当 s1.insert(0, ‘x’) 时,当 end 减到 -1 时,本来应该结束了,但是它还会走,因为这里当无符号和有符号比较时,进行整型提升了,这里的 -1 会被提升为一个很大的正数。解决方法:
  1. 将参数的 size_t pos 改成 int pos,但不符合设计的意义
  2. 在 while 循环里比较时,将 pos 强转为 int
  3. 将 end 的值改成 _size + 1,具体见详细代码
这里就非常考验 C语言的基本功了,如果你不知道这个提升机制,甚至你在调试的时候都会怀疑是编译器的 bug。
对于erase 的实现,它的第二个参数我们给的是一个缺省值 npos,它是无符号的 -1。
一般我们重载流提取、流插入都是全局的。在实现日期类时,我们也写过,那里需要使用到友元,但是流提取和流插入必须是友元这句话是不对的,日期类里的友元,是要突破封装访问日期类的年月日,这里不一定要去访问。比如流插入的 operator[] 是公有的,流提取提供的 += 是公有的。
对于上面的 operator<<,我们发现它并不能提取我们输入的字符。其实这里的 in 是拿不到换行符或空格的,C语言中的 scanf 也是这样的,对于 C语言它可以使用 getchar 来解决,这里我们可以看到 C++ 中 cin 对象里也有类似的接口 get。
其次 operator>> 里还有个问题,当对 s1 字符串继续 cin >> s1 时,新输入的字符串会补在原字符串的后面,所以这里我们还要提供一个 clear 接口,在 operator>> 的第一行 clear。
以上两种 cout 有无区别 ???
一般情况下没有啥区别,但在某种场景下有区别,这种场景很不容易被发现。这里对 s2 resize 后,它会变成 hello\0\0\0\0…x,此时第一个 cout 会全部输出,因为它是按 _size 走的;第二个 cout 不会输出,因为它遇到 \0 就终止。所以大部分情况我们都用第一种 cout,因为它有保障。
这里我们输入 hello world,但只获取到了 hello,这个原因是 cin 是以空格或换行结束的,它认为 hello 和 world 是给两个对象的,所以这里就实现了 getline>>。注意这里的实现和 operator>> 是一样的,不同的地方是 getline 遇到换行才结束。
对于 operator> 写成成员或全局都可以,我们这里根据库里来实现写成全局。注意这里比较的是 ASCII 码。这里比较有如下情况:
  1. “abc”  “aa”
  2. “aa”    “abc”
  3. “abc”  “abc”
  4. “abcd” “abc”
  5. “abc”   “abcd"
当我们实现了 operator>、operator==,那么其它的就可以直接复用了,且实现为 inline,避免建立函数栈帧所带来的开销。
注意 operator+ 尽量少用,因为它内部需要两次深拷贝。
对于 find 我们这里只实现查找字符和查找字符串
💦 补充
如下 s1 和 s2 对象的大小为什么是 28 字节 ❓
根据我们实现的 string 类,应该只有 12 字节,凭空多出的 16 字节是怎么来的 ?
这其实是 VS 下面的一个技术优化(也可以说是 PJ 版本自己考虑的),调试发现除了 size、capacity、指针,还多了很多东西。
也就是说你的字符个数小于 16,它不会去堆上开空间,而是存储在 _Buf 数组里;如果字符个数大于等于 16,它就会存储在 _str 指向的堆上。这种方式的好处就是对于小空间不用去系统去申请了,减少内存碎片。
Linux 下 s1 和 s2 的大小 ❗
💦 扩展阅读
面试中string的一种正确写法
STL的string类怎么啦?
