CodeArts代码重构
HuaweiCloud开发工具 发表于 2022/06/13 15:21:44 2022/06/13
【摘要】 重构是通过改变现有程序结构而不改变其功能和用途来提高代码的可重用性和可维护性。
CodeArts支持重构操作,提供了多种重要的重构类型,如下:
CodeArts支持的重构操作
重构类型 支持操作 快捷键
重命名 Rename Symbol Shift+F6
提取重构 Extract Superclass
Extract Method Object
Extract Method Ctrl+Alt+Shift+M
Extract Interface
Extract Delegate...
Encapsulate Fields
引入重构 Introduce Variable  Ctrl+Alt+V
Introduce Parameter Ctrl+Alt+Shift+P
Introduce Parameter Object
Introduce Functional Variable
Introduce Functional Parameter
Introduce Field Ctrl+Alt+Shift+F
Introduce Constant  Ctrl+Alt+C
复制重构 Copy Class  Shift+F5
移动和更改重构 Push members down
Pull members up
Move inner class to Upper level
Make Static
Change Method Signature Ctrl+F6
Change Class Signature Ctrl+F6
Type Migration
查找和替换重构 Replace Inheritance with Delegation
Replace Constructor with Factory Method
Replace Constructor with Builder
内联重构 Inline Variable
Inline to Anonymous Class
Inline Super Class
Inline Parameter Ctrl+Alt+Shift+P
Inline Method  Ctrl+Alt+Shift+L
Inline Field
其它重构
Invert Boolean
Use Interface Where Possible
Convert Raw Types to Generics
Convert To Instance Method
Remove Middleman
Safe Delete
Alt+Del
Move Static Members
