python setup.py build命令解析
风吹稻花香 发表于 2022/06/08 23:34:31 2022/06/08
【摘要】 python ——setup.py build_ext --inplace命令解析 1. 用python setup.py --help-commands 首先要有个setup.py,用setuptools实现python的setup,这里是一个setup.py的例子: from setuptools import setu...
from setuptools import setup
from setuptools import Extension
example_module = Extension(name='numpy_demo',  # 模块名称
                           sources=['example.cpp'],    # 源码
                           include_dirs=[r'/home/data/CM/10_device/pybind11/include']
setup(ext_modules=[example_module])
该例子是用pybind11模块,用c++给python写一个模块
2. 命令解析
  • build_ext:build C/C++ extensions (compile/link to build directory),给python编译一个c、c++的拓展
  • –inplace:ignore build-lib and put compiled extensions into the source directory alongside your pure Python modules,忽略build-lib,将编译后的扩展放到源目录中,与纯Python模块放在一起
文章来源: blog.csdn.net,作者:AI视觉网奇,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jacke121/article/details/125185764
