202206-4|BBoss-ES操作数据及抽ES数据存到List数组
写程序的小王叔叔 发表于 2022/06/07 07:06:52 2022/06/07
【摘要】 ​主页:小王叔叔的博客支持:点赞👍关注✔️收藏💖一、BBoss-ES操作数据 1、pom.xml<dependency> <groupId>com.bbossgroups.plugins</groupId> <artifactId>bboss-elasticsearch-spring-boot-starter</artifactId> ...
​主页:小王叔叔的博客
支持:点赞👍关注✔️收藏💖
一、BBoss-ES操作数据
1、pom.xml
<dependency>
            <version>6.0.0</version>
            <exclusions>
                <exclusion>
                    <artifactId>slf4j-log4j12</artifactId>
                    <groupId>org.slf4j</groupId>
                </exclusion>
            </exclusions>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
         <dependency>
            <groupId>org.elasticsearch.client</groupId>
            <artifactId>elasticsearch-rest-client</artifactId>
         <version>${elasticsearch.version}</version>
       </dependency>
      <dependency>
         <artifactId>elasticsearch-rest-high-level-client</artifactId>
      </dependency>
2、基本配置
elasticsearch:
    host: 10.1*.**.**
    port: 9200
    bboss:
      default:
        elasticPassword: elastic
        elasticUser: elastic
        elasticsearch:
          dateFormat: yyyy.MM.dd
          discoverHost: false
          rest:
            hostNames: 1*.**.**.**:9200
          scrollBlockedWaitTimeout: 0
          scrollThreadCount: 200
          scrollThreadQueue: 200
          showTemplate: true
          sliceScrollBlockedWaitTimeout: 0
          sliceScrollThreadCount: 100
          sliceScrollThreadQueue: 100
          timeZone: Asia/Shanghai
        http:
          connectionRequestTimeout: 5000
          customHttpRequestRetryHandler: org.frameworkset.spi.remote.http.ConnectionResetHttpRequestRetryHandler
          defaultMaxPerRoute: 200
          hostnameVerifier: ''
          keyPassword: ''
          keystore: ''
          maxHeaderCount: 200
          maxLineLength: -1
          maxTotal: 400
          retryTime: 1
          staleConnectionCheckEnabled: false
          timeoutConnection: 5000
          timeoutSocket: 5000
          validateAfterInactivity: 2000
      dslfile:
        refreshInterval: -1
3、结构配置
3.1 配置ESSTartConfigurer
import org.frameworkset.elasticsearch.boot.BBossESStarter;
import org.springframework.boot.context.properties.ConfigurationProperties;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.context.annotation.Primary;
@Configuration
public class ESSTartConfigurer {
  @Primary
  @Bean(initMethod = "start")
  @ConfigurationProperties("spring.elasticsearch.bboss.default")
  public BBossESStarter bbossESStarter(){
    return new BBossESStarter();
3.2配置EsQueryToolsConfig
import com.alibaba.fastjson.JSONObject;
import org.frameworkset.elasticsearch.client.ClientInterface;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Component;
@Component
public class EsQueryToolsConfig {
    @Autowired
    private BBossESStarter bbossESStarterDefault;
     * 用sql查询
     * @param sql
     * @return
    public String queryForSQL(String sql){
        ClientInterface clientUtil = bbossESStarterDefault.getRestClient();
        JSONObject jsonObject = new JSONObject();
        jsonObject.put("sql",sql);
        String rtnJson = clientUtil.executeHttp("/_sql/", jsonObject.toJSONString(), ClientInterface.HTTP_POST);
        return rtnJson;
     * 用原生的 es的dsl查询
     * @param indexName
     * @param dsl
     * @return
    public String queryForDSL(String indexName,String dsl) {
        String rtnJson = clientUtil.executeHttp("/" + indexName + "/_search", dsl, ClientInterface.HTTP_POST);
        return rtnJson;
4、CRUD
4.1 - C
在业务接口 **impl 中,实现基本业务逻辑。
代码块代表当前业务逻辑,具体问题具体分析。
@Service
public class TeacherResourceServiceImpl implements TeacherResourceService {
    @Autowired
    private TeacherResourceDao teacherResourceDao;
    @Autowired
    private ElasticsearchRestTemplate elasticsearchRestTemplate;
    @Override
    public PageInfo<TeacherResourceVO> findTeacherResourceFromES(T*****TO t***TO) throws  Exception{
        List t*******OsList = new ArrayList();
        PageInfo<T******O> teacherResPages = new PageInfo<>();
        if (elasticsearchRestTemplate.indexExists("s*******n")){
            //聚合获取学校id-教师id的相关信息
            String teacherResJson = teacherResourceDao.findTeacherResourceList(t*******TO) ;
            JSONObject buildTeacherObj = JSONObject.parseObject(teacherResJson);
            JSONArray buildTeacherArr = buildTeacherObj.getJSONObject("aggregations").getJSONObject("b*******_id").getJSONArray("buckets");
            for (int i = 0; i < buildTeacherArr.size(); i++) {
                TeacherResourceVO teacherResourceVO = new TeacherResourceVO();
                JSONObject teacherObj = buildTeacherArr.getJSONObject(i);
                if (null != teacherObj) {
                    String teacherId = teacherObj.getString("key");
                    String teacherNameJson = teacherResourceDao.getUserNameFromES(teacherId);
                    JSONObject teacherNameObj = JSONObject.parseObject(teacherNameJson);
                    String teacherName = teacherNameObj.getJSONObject("hits").getJSONArray("hits").getJSONObject(0).getJSONObject("_source").getString("user_name");
                    JSONObject schoolNameObj = JSONObject.parseObject(schoolNameJson);
                    String schoolName = schoolNameObj.getJSONObject("hits").getJSONArray("hits").getJSONObject(0).getJSONObject("_source").getString("organization_name");
                    teacherResourceVO.setTeacherId(teacherId);
                    teacherResourceVO.setTeacherName(teacherName);
                    teacherResourceVO.setRecourceAccount(Integer.parseInt(teacherResCount));
                    teacherResourceVOsList.add(teacherResourceVO);
            Integer totalNum = teacherResourceVOsList.size();
            int pageNum =teacherResourceDTO.getPageNum();
            int pageSize = teacherResourceDTO.getPageSize();
            Integer totalPage = 0;
            if (totalNum > 0) {
                totalPage = totalNum % pageSize == 0 ? totalNum / pageSize : totalNum / pageSize + 1;
            if (pageNum > totalPage) {
                pageNum = totalPage;
            int startPoint = (pageNum - 1) * pageSize;
            int endPoint = startPoint + pageSize;
            if (totalNum <= endPoint) {
                endPoint = totalNum;
            List PageList = new ArrayList();
            PageList =  t******OsList.subList(startPoint, endPoint);
            teacherResPages.setPageNum(t*****TO.getPageNum());
            teacherResPages.setPageSize(t*******O.getPageSize());
            teacherResPages.setTotal(t******sList.size());
            teacherResPages.setPages(totalPage );
            teacherResPages.setList(PageList);
            return teacherResPages;
在dao层 引入文件【见上】:
@Autowired
    private EsQueryToolsConfig esQueryToolsConfig;
     * 获取学校教师资源数量
     * @param teacherResourceDTO
     * @return
     * @throws Exception
    public String findTeacherResourceList(T*******O *****O) throws  Exception{
        SimpleDateFormat simpleDateFormat = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
        //基础sql
        String select_sql = "select base_user_id , count(*) as teacherResCount  from  s*******n ";
        String where_sql = "where  1=1 ";
        String groupBy_sql = "group by base_user_id ";
        String order_sql = " order by teacherResCount desc   limit 10";
        if(StringUtils.isNotBlank(t********O.getSchoolId())){
            where_sql = where_sql.concat(" and b******_id = '" + t*******O.getSchoolId() + "' ");
        if (StringUtils.isNotBlank(te*****O.getBeginDate())) {
            long  beginTime = simpleDateFormat.parse(t*****O.getBeginDate() + LoginConstant.START_TIME).getTime();
            where_sql = where_sql.concat( " and create_time >= '" + beginTime + "' ");
        if (StringUtils.isNotBlank(t******O.getEndDate())) {
            long  endTime = simpleDateFormat.parse(te********O.getEndDate() + LoginConstant.END_TIME).getTime();
            where_sql = where_sql.concat( " and create_time < '" + endTime + "' ");
        String sql = select_sql + where_sql + groupBy_sql   ;
        String retJson = this.esQueryToolsConfig.queryForSQL( sql );
        System.out.println(sql);
        return retJson;
二、抽ES数据存到List数组
//自定义 学科名称数组
        ArrayList arraySubList = new ArrayList();
        ArrayList arraySubIdList = new ArrayList();
        if (elasticsearchRestTemplate.indexExists("s*******************b")) {
            SearchQuery searchQuery = new NativeSearchQueryBuilder()
                    .withIndices("s************b")
                    .withTypes("_***************")
                    .withQuery(boolQuery)
                    .build();
            //统计学生的发布课程信息
            List<St***************O> s*************Os = elasticsearchRestTemplate.queryForList(searchQuery, S*************O.class);
            //根据学生发布课程编号获取学段,学科基本信息
            for (int i = 0; i < stuIssueD**********s.size(); i++) {
                String strCourseId = stu************s.get(i).getCourse_base_id();
                //课程统计
                BoolQueryBuilder queryCourseInfo = QueryBuilders.boolQuery();
                queryCourseInfo.must(QueryBuilders.termQuery("co******id", strCourseId));
                SearchQuery queryCourse = new NativeSearchQueryBuilder()
                        .withIndices("s****************o")
                        .withTypes("_d************************")
                        .withQuery(queryCourseInfo)
                        .build();
                List<Co******O> co*************List = elasticsearchRestTemplate.queryForList(queryCourse, C***********O.class);
                for (int j = 0; j < co**********ist.size(); j++) {
                    BoolQueryBuilder querySubInfo = QueryBuilders.boolQuery();
                    //学段信息
                    if (StringUtils.isNotBlank(subjectId)) {
                        querySubInfo.must(QueryBuilders.termQuery("s******de", subjectId));
                        querySubInfo.must(QueryBuilders.termQuery("s***********de", courseVOFromESList.get(j).getBusiness_subject_id()));
                    //学科信息
                    if (StringUtils.isNotBlank(stageId)) {
                        querySubInfo.must(QueryBuilders.termQuery("s******de", stageId));
                        querySubInfo.must(QueryBuilders.termQuery("s*******de", courseVOFromESList.get(j).getBu*******_id()));
                    SearchQuery querySubjectInfo = new NativeSearchQueryBuilder()
                            .withIndices("st*********t")
                            .withTypes("_***********c")
                            .withQuery(querySubInfo)
                            .build();
                    List<Su***********O> subList = elasticsearchRestTemplate.queryForList(querySubjectInfo, Su*********O.class);
                    //动态添加 - list数组
                   //动态添加 - list数组
                    arraySubList.add(subList.get(0).getSubject_name());
                    arraySubIdList.add(subList.get(0).getSubject_code());
            List<St**********O> s**************List = homeworkService.getQuestionAndknowledgeTotal(s****************O);
            for (int i = 0; i < st************List.size(); i++) {
                //学生学习的课程数量
                st**************List.get(i).setResourceAccount(s************s.size());
                stud**************List.get(i).setSubjectId(subjectId);
                //学科名称
           subList.stream().map(S*******::getSubject_name).collect(Collectors.toList());
              //  studentSubResourceVOList.get(i).setSubjectName(subName.toString());
            return studentSubResourceVOs;
转载声明:本文为博主原创文章,未经博主允许不得转载
⚠️注意 ~
💯本期内容就结束了,如果内容有误,麻烦大家评论区指出!
如有疑问❓可以在评论区留言💬或私信留言💬,尽我最大能力🏃‍♀️帮大家解决👨‍🏫!
如果我的文章有帮助到您,欢迎点赞+关注✔️鼓励博主🏃,您的鼓励是我分享的动力🏃🏃🏃~
