Android Fragment回退
yechaoa 发表于 2022/05/31 01:12:16 2022/05/31
【摘要】 假设场景:登录、注册 MainActivity初始化和监听返回键 @Override protected void onCreate(Bundle savedInstanceState...
假设场景:登录、注册
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mFragmentManager = getSupportFragmentManager();
        addFragment(new LoginFragment(), "login");
    public void addFragment(Fragment fragment, String tag) {
        FragmentTransaction beginTransaction = mFragmentManager.beginTransaction();
        beginTransaction.add(R.id.login_content, fragment, tag);
        // 添加到回退栈,并定义标记
        beginTransaction.addToBackStack(tag);
        beginTransaction.commit();
     * 监听返回键
    @Override
    public boolean onKeyDown(int keyCode, KeyEvent event) {
        if (keyCode == KeyEvent.KEYCODE_BACK) {
            // 获取当前回退栈中的Fragment个数
            int backStackEntryCount = mFragmentManager.getBackStackEntryCount();
            // 回退栈中至少有多个fragment,栈底部是首页
            if (backStackEntryCount > 1) {
                // 回退一步
                mFragmentManager.popBackStackImmediate();
                // 获取当前退到了哪一个Fragment上,重新获取当前的Fragment回退栈中的个数
                FragmentManager.BackStackEntry backStack = mFragmentManager.getBackStackEntryAt(mFragmentManager.getBackStackEntryCount() - 1);
                // 获取当前栈顶的Fragment的标记值
                String tag = backStack.getName();
                if (tag.equals("login")) {
                    if (isLogin) {
                        isLogin = false;
                    } else
                        finish();
                finish();
        return true;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
LoginFragment中的事件处理
    @OnClick({R.id.btn_register})
    public void onViewClicked(View view) {
        switch (view.getId()) {
            case R.id.btn_register:
                LoginActivity activity = (LoginActivity) getActivity();
                activity.addFragment(new RegisterFragment(), "register");
                FragmentTransaction fragmentTransaction = getActivity().getSupportFragmentManager().beginTransaction();
                fragmentTransaction.hide(getActivity().getSupportFragmentManager().findFragmentByTag("login"));
                fragmentTransaction.commit();
                break;
RegisterFragment中的事件处理
    @OnClick({R.id.btn_back})
            case R.id.btn_back:
                fragmentTransaction.show(getActivity().getSupportFragmentManager().findFragmentByTag("login"));
                fragmentTransaction.hide(getActivity().getSupportFragmentManager().findFragmentByTag("register"));
                break;
文章来源: blog.csdn.net,作者:yechaoa,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/yechaoa/article/details/80370231
