Android 倒计时 仿京东
yechaoa 发表于 2022/05/31 00:19:41 2022/05/31
【摘要】 效果 xml <LinearLayout android:layout_width="wrap_content" android:layout_height="wrap_co...
效果
这里写图片描述
xml
<LinearLayout
    android:layout_height="wrap_content"
    android:orientation="horizontal">
    <TextView
        android:layout_marginRight="@dimen/dp_10"
        android:text="距结束"/>
    <TextView
        android:id="@+id/tv_seckill_hour"
        android:background="@drawable/shape_bg_black_corners"
        android:paddingLeft="@dimen/dp_4"
        android:paddingRight="@dimen/dp_4"
        android:text="00"
        android:textColor="@color/white"/>
    <TextView
        android:text=" : "/>
    <TextView
        android:id="@+id/tv_seckill_minute"
        android:text="00"
    <TextView
    <TextView
        android:id="@+id/tv_seckill_second"
        android:text="00"
</LinearLayout>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
shape
<shape xmlns:android="http://schemas.android.com/apk/res/android">
    <corners android:radius="5dp"/>
    <solid android:color="@color/black"/>
</shape>
java
1、计算时间
* 倒计时
private void countDown() {
   SimpleDateFormat df = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss", Locale.CHINA);
   Date curDate = new Date(System.currentTimeMillis());
   String format = df.format(curDate);
   try {
       //时间换算
       Date date = df.parse(mEndTime);
       Date date1 = df.parse(format);
       long defTime = date.getTime() - date1.getTime();
       long days = defTime / (1000 * 60 * 60 * 24);
       long hours = (defTime - days * (1000 * 60 * 60 * 24)) / (1000 * 60 * 60);
       long minute = (defTime - days * (1000 * 60 * 60 * 24) - hours * (1000 * 60 * 60)) / (1000 * 60);
       long seconds = defTime % 60000;
       long second = Math.round((float) seconds / 1000);
       //不足10的补0
       if (hours >= 10) mTvSeckillHour.setText(String.valueOf(hours));
       else mTvSeckillHour.setText(String.valueOf("0" + hours));
       if (minute >= 10) mTvSeckillMinute.setText(String.valueOf(minute));
       else mTvSeckillMinute.setText(String.valueOf("0" + minute));
       if (second >= 10) mTvSeckillSecond.setText(String.valueOf(second));
       else mTvSeckillSecond.setText(String.valueOf("0" + second));
   } catch (ParseException e) {
       e.printStackTrace();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
2、在需要的地方调用handler
   //开启倒计时
   handler.sendEmptyMessage(0);
3、handler中处理
    @SuppressLint("HandlerLeak")
    private Handler handler = new Handler() {
        @Override
        public void handleMessage(Message msg) {
            super.handleMessage(msg);
            countDown();
            sendEmptyMessageDelayed(0, 1000);
更多:60s倒计时
文章来源: blog.csdn.net,作者:yechaoa,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/yechaoa/article/details/82388519
