Flutter 流式布局之Wrap
yechaoa 发表于 2022/05/30 23:53:23 2022/05/30
【摘要】 效果: Wrap A widget that displays its children in multiple horizontal or vertical runs. 一个可以横向或...
效果:
Wrap
一个可以横向或纵向显示的流式布局的widget
使用场景:一行显示不下需要换行的时候
源码
  Wrap({
    Key key,
    this.direction = Axis.horizontal,//方向
    this.alignment = WrapAlignment.start,//对齐方式
    this.spacing = 0.0,//子widget 横向的间隔
    this.runAlignment = WrapAlignment.start,
    this.runSpacing = 0.0,//当横向时子widget纵向的间隔
    this.crossAxisAlignment = WrapCrossAlignment.start,
    this.textDirection,//文本方向
    this.verticalDirection = VerticalDirection.down,
    List<Widget> children = const <Widget>[],//子widget
  }) : super(key: key, children: children);
示例
     Wrap(
       spacing: 8.0, // gap between adjacent chips
       runSpacing: 4.0, // gap between lines
       children: <Widget>[
         Chip( label: Text('Hamilton') ),
         Chip( label: Text('Lafayette') ),
         Chip( label: Text('Mulligan') ),
         Chip( label: Text('Laurens') ),
官方文档:https://api.flutter.dev/flutter/widgets/Wrap-class.html
文章来源: blog.csdn.net,作者:yechaoa,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/yechaoa/article/details/90403760
