Flutter BottomNavigationBar不显示(显示白色)?
yechaoa 发表于 2022/05/30 23:26:42 2022/05/30
【摘要】 BottomNavigationBar 超过3个之后不显示(显示白色)? 官网文档解释: The bottom navigation bar’s type changes how its...
官网文档解释:
The bottom navigation bar’s type changes how its items are displayed. If not specified it’s automatically set to
BottomNavigationBarType.fixed when there are less than four items,
BottomNavigationBarType.shifting otherwise.
  • BottomNavigationBarType.fixed, the default when there are less than four items. The selected item is rendered with fixedColor if it’s
    non-null, otherwise the theme’s ThemeData.primaryColor is used. The
    navigation bar’s background color is the default Material background
    color, ThemeData.canvasColor (essentially opaque white).
  • BottomNavigationBarType.shifting, the default when there are four or more items. All items are rendered in white and the navigation bar’s
    background color is the same as the
    BottomNavigationBarItem.backgroundColor of the selected item. In this
    case it’s assumed that each item will have a different background
    color and that background color will contrast well with white.
解决办法:
加一个type属性:
type: BottomNavigationBarType.fixed,
文章来源: blog.csdn.net,作者:yechaoa,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/yechaoa/article/details/89852088
