flutter No Material widget found.
yechaoa 发表于 2022/05/31 00:13:06 2022/05/31
【摘要】 I/flutter (25517): No Material widget found. I/flutter (25517): ListTile widgets require a Material wi...
I/flutter (25517): ListTile widgets require a Material widget ancestor.
I/flutter (25517): In material design, most widgets are conceptually "printed" on a sheet of material. In Flutter's
I/flutter (25517): material library, that material is represented by the Material widget. It is the Material widget
I/flutter (25517): that renders ink splashes, for instance. Because of this, many material library widgets require that
I/flutter (25517): there be a Material widget in the tree above them.
I/flutter (25517): To introduce a Material widget, you can either directly include one, or use a widget that contains
I/flutter (25517): Material itself, such as a Card, Dialog, Drawer, or Scaffold.
I/flutter (25517): The specific widget that could not find a Material ancestor was:
简而言之:
使用了Material 风格的widget 就需要Scaffold作为根布局
什么是Material 风格的widget,比如
  • AppBar
  • BottomAppBar
  • FloatingActionButton
  • Drawer
  • SnackBar
  • BottomSheet
  • BottomNavigationBar
  • ListTile
  • 等等
需要Scaffold作为根布局,意为用Scaffold包裹起来即可
return Scaffold(
      appBar: AppBar( ),
      bottomNavigationBar: BottomNavigationBar( ),
      floatingActionButton: FloatingActionButton( ),
      drawer: Drawer(),
文章来源: blog.csdn.net,作者:yechaoa,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/yechaoa/article/details/90693377
