【运动学】基于matlab GUI模拟鱼类目标追击问题【含Matlab源码 166期】
海神之光 发表于 2022/05/30 23:39:35 2022/05/30
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【运动学】基于matlab GUI模拟鱼类目标追击问题【含Matlab源码 166期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = TorpedoAndAim(varargin)
% TORPEDOANDAIM MATLAB code for TorpedoAndAim.fig
%      TORPEDOANDAIM, by itself, creates a new TORPEDOANDAIM or raises the existing
%      singleton*.
%      H = TORPEDOANDAIM returns the handle to a new TORPEDOANDAIM or the handle to
%      TORPEDOANDAIM('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in TORPEDOANDAIM.M with the given input arguments.
%      TORPEDOANDAIM('Property','Value',...) creates a new TORPEDOANDAIM or raises the
%      applied to the GUI before TorpedoAndAim_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to TorpedoAndAim_OpeningFcn via varargin.
% Edit the above text to modify the response to help TorpedoAndAim
% Last Modified by GUIDE v2.5 22-Jun-2021 20:00:58
gui_Singleton = 1;
                   'gui_OpeningFcn', @TorpedoAndAim_OpeningFcn, ...
                   'gui_OutputFcn',  @TorpedoAndAim_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before TorpedoAndAim is made visible.
function TorpedoAndAim_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to TorpedoAndAim (see VARARGIN)
% Choose default command line output for TorpedoAndAim
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes TorpedoAndAim wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = TorpedoAndAim_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
AimSpeed=str2double(get(handles.edit1,'string'));  %目标初始速度
AimSpeedAngel=str2double(get(handles.edit2,'string'));  %目标速度与x方向夹角
TorpedoSpeed=str2double(get(handles.edit3,'string'));    %鱼雷速度
AimOriginX=str2double(get(handles.edit4,'string'));   %目标初始位置
AimOriginY=str2double(get(handles.edit5,'string'));
TorpedoOriginX=str2double(get(handles.edit6,'string'));  %鱼雷初始位置
TorpedoOriginY=str2double(get(handles.edit7,'string'));
%-------------%%输入完毕—————————————
AimSpeedAngel=AimSpeedAngel/180*pi;        %角度转弧度
AimSpeedX=AimSpeed*cos(AimSpeedAngel);       %目标速度x分量
AimSpeedY=AimSpeed*sin(AimSpeedAngel);     %目标速度y分量
TorpedoX=TorpedoOriginX;
TorpedoY=TorpedoOriginY;
t=0;t0=0.1;
axes(handles.axes1);
while(1)
    t=t+t0;
    set(handles.text12,'string',[num2str(t),'s']);
    AimX=AimOriginX+AimSpeedX*t;
    AimY=AimOriginY+AimSpeedY*t;
    ATAngel=atan((AimY-TorpedoY)/(AimX-TorpedoX));    %舷角
    if AimX>=TorpedoX&&AimY>=TorpedoY       %%鱼雷路径优化
        TorpedoX=TorpedoX+TorpedoSpeed*cos(ATAngel)*t0;
        TorpedoY=TorpedoY+TorpedoSpeed*abs(sin(ATAngel))*t0;
    elseif AimX<TorpedoX&&AimY>=TorpedoY
        TorpedoX=TorpedoX-TorpedoSpeed*cos(ATAngel)*t0;
    elseif AimX>=TorpedoX&&AimY<TorpedoY
        TorpedoY=TorpedoY-TorpedoSpeed*abs(sin(ATAngel))*t0;
    else
    end
    h1=plot(TorpedoX,TorpedoY,'*');             %鱼雷路径为***线
    xlabel('x方向','Fontsize',16);
    ylabel('y方向','Fontsize',16);
    hold on
    h2=plot(AimX,AimY,'.');                     %目标路径为...线
    r=(AimY-TorpedoY)^2+(AimX-TorpedoX)^2;      %鱼目距离
    if(r)<=1                                    %击中判定
        set(handles.text11,'string','成功击中目标!');
        break;
    end
    if(t>60)                                    %丢失判定
        set(handles.text11,'string','超时!丢失目标!');
        break;
    end
    pause(0.01);
end
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/122219320
