【语音处理】基于matlab GUI音频信号处理(调音+调速+调频+滤波)(带面板)【含Matlab源码 299期】
海神之光 发表于 2022/05/30 00:54:28 2022/05/30
【摘要】 一、语音处理简介 MATLAB GUI是用户与计算机或计算机程序的接触点或交互方式,是用户与计算机进行信息交流的方式。图形用户界面(Graphical User Interfaces,GUI)则是由窗口...
一、语音处理简介
MATLAB GUI是用户与计算机或计算机程序的接触点或交互方式,是用户与计算机进行信息交流的方式。图形用户界面(Graphical User Interfaces,GUI)则是由窗口、光标、按键、菜单、文字说明等对象(Object)构成的一个用户界面。用户通过一定的方法(如鼠标或键盘)选择、激活这些图形对象,使计算机产生某种动作或变化,比如实现计算、绘图等。本设计基于MATLAB GUI技术,完成了语音信号处理的界面平台,可进行语音的选取、线性预测分析(LPC)、语谱图、频谱等相关波形的显示。这样可以更直观、更方便地分析和处理语音信号,得到用户需要的实验结果。
具体理论知识参考:基于MATLAB GUI的语音处理界面设计
二、部分源代码
function varargout = yonghujiemain(varargin)
% YONGHUJIEMAIN M-file for yonghujiemain.fig
%      YONGHUJIEMAIN, by itself, creates a new YONGHUJIEMAIN or raises the existing
%      singleton*.
%      H = YONGHUJIEMAIN returns the handle to a new YONGHUJIEMAIN or the handle to
%      YONGHUJIEMAIN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in YONGHUJIEMAIN.M with the given input arguments.
%      YONGHUJIEMAIN('Property','Value',...) creates a new YONGHUJIEMAIN or raises the
%      applied to the GUI before yonghujiemain_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to yonghujiemain_OpeningFcn via varargin.
% Edit the above text to modify the response to help yonghujiemain
% Last Modified by GUIDE v2.5 02-Jan-2021 16:50:18
gui_Singleton = 1;
                   'gui_OpeningFcn', @yonghujiemain_OpeningFcn, ...
                   'gui_OutputFcn',  @yonghujiemain_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before yonghujiemain is made visible.
function yonghujiemain_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to yonghujiemain (see VARARGIN)
% Choose default command line output for yonghujiemain
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes yonghujiemain wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = yonghujiemain_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in turn_down.
function turn_down_Callback(hObject, eventdata, handles)
% hObject    handle to turn_down (see GCBO)
% --- Executes on button press in turn_up.
function turn_up_Callback(hObject, eventdata, handles)
% hObject    handle to turn_up (see GCBO)
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% Hints: contents = get(hObject,'String') returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in speed_up.
function speed_up_Callback(hObject, eventdata, handles)
% hObject    handle to speed_up (see GCBO)
% --- Executes on button press in slow_down.
function slow_down_Callback(hObject, eventdata, handles)
% hObject    handle to slow_down (see GCBO)
% --- Executes on selection change in popupmenu2.
function popupmenu2_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu2 (see GCBO)
% Hints: contents = get(hObject,'String') returns popupmenu2 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu2
function popupmenu2_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in insert.
function insert_Callback(hObject, eventdata, handles)
% hObject    handle to insert (see GCBO)
global  fn x Fs bits;
[fn,dirpath]=uigetfile('*.wav');
[x,Fs,bits] = wavread(fn);
t=(0:length(x)-1)/Fs;
plot(handles.axes1,t,x);
legend('Waveform');
xlabel( 'Time(s)');
ylabel('Amplitude');
xlength=length(x);
y=fft(x,xlength);
Pyy =y.*conj(y)/xlength;
f = 22050*(0:(xlength/2))/xlength;
plot(handles.axes2,f,Pyy(1:xlength/2+1));
title('Frequency content of y');
xlabel('frequency (Hz)');
% --- Executes on button press in play.
function play_Callback(hObject, eventdata, handles)
% hObject    handle to play (see GCBO)
global  x Fs bits;
sound(x,Fs,bits);
% --- Executes on button press in save.
function save_Callback(hObject, eventdata, handles)
% hObject    handle to save (see GCBO)
global x;
[filname,pathname]=uiputfile('.wav');
wavwrite(x,22050,8,filname);
% --- Executes on button press in radiobutton1.
function radiobutton1_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton1 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton1
% --- Executes on button press in radiobutton2.
function radiobutton2_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton2 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton2
% --- Executes on button press in fuwei.
function fuwei_Callback(hObject, eventdata, handles)
% hObject    handle to fuwei (see GCBO)
legend('Waveform');
xlabel( 'Time(s)');
xlength=length(x);
y=fft(x,xlength);
% --- Executes on button press in daofang.
function daofang_Callback(hObject, eventdata, handles)
% hObject    handle to daofang (see GCBO)
global   x Fs ;
i=1:length(x);
j=length(x):-1:1;
x_reversal(j)=x(i); %实现声音数据颠倒
title('original signal');
xlabel( 'Time(s)');
plot(handles.axes2,t,x_reversal);
title('reversal signal');
xlabel( 'Time(s)');
x=x_reversal;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
[3]宋云飞,姜占才,魏中华.基于MATLAB GUI的语音处理界面设计[J].科技信息. 2013,(02)
原文链接:qq912100926.blog.csdn.net/article/details/113800964
