【游戏】基于 matlab GUI lanchester作战模拟设计【含Matlab源码 426期】
海神之光 发表于 2022/05/30 01:00:48 2022/05/30
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【游戏】基于 matlab GUI lanchester作战模拟设计【含Matlab源码 426期】 获取代码方式2: 通过订阅紫极神光博客...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = lcst(varargin)
% LCST M-file for lcst.fig
%      LCST, by itself, creates a new LCST or raises the existing
%      singleton*.
%      H = LCST returns the handle to a new LCST or the handle to
%      LCST('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in LCST.M with the given input arguments.
%      LCST('Property','Value',...) creates a new LCST or raises the
%      applied to the GUI before lcst_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to lcst_OpeningFcn via varargin.
% Edit the above text to modify the response to help lcst
% Last Modified by GUIDE v2.5 26-Oct-2008 20:07:52
gui_Singleton = 1;
                   'gui_OpeningFcn', @lcst_OpeningFcn, ...
                   'gui_OutputFcn',  @lcst_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before lcst is made visible.
function lcst_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to lcst (see VARARGIN)
axes(handles.axes2);
[x1,map]=imread('1.jpg');
[x2,map]=imread('2.jpg');
x3=imread('3.jpg');
 x4=imread('4.jpg');
x5=imread('5.jpg');
x6=imread('6.jpg');
x7=imread('7.jpg');
x8=imread('8.jpg');x9=imread('9.jpg');x10=imread('10.jpg');x11=imread('11.jpg');
M(1)=im2frame(x1,map);
M(2)=im2frame(x2,map);M(3)=im2frame(x3,map);
M(4)=im2frame(x4,map);M(5)=im2frame(x5,map);
M(6)=im2frame(x6,map);M(7)=im2frame(x7,map);
M(8)=im2frame(x8,map);M(9)=im2frame(x9,map);
M(10)=im2frame(x10,map);
M(11)=im2frame(x11,map);
movie(M,1000,3)
% Choose default command line output for lcst
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% This sets up the initial plot - only do when we are invisible
% so window can get raised using lcst.
% UIWAIT makes lcst wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = lcst_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in simulation.
function simulation_Callback(hObject, eventdata, handles)
% hObject    handle to simulation (see GCBO)
axes(handles.axes1);
cla;
x0=str2double(get(handles.red1,'String'));
 a=str2double(get(handles.red2,'String'));
 y0=str2double(get(handles.blue1,'String'));
 b=str2double(get(handles.blue2,'String'));
%  for k=1:100
%      t(k)=et/100*k
%         x(k)=x0-a*t(k);
%         y(k)=y0-b*t(k);
%  end
popup_sel_index = get(handles.popupmenu1, 'Value');%根据不同的定律进行计算
switch popup_sel_index
    case 1
        if a*y0>b*x0
    et=x0/a;
    Rb=(a*y0-b*x0)/a;
    Rr=0;
    w='蓝方';
end
if a*y0<b*x0
    et=y0/b;
    Rr=(b*x0-a*y0)/b;
    Rb=0;
    w='红方';
end
if a*y0==b*x0
    et=x0/a;
    Rr=0;
    Rb=0;
    w='同归于尽';
end
        set(handles.winp,'string',w);
        set(handles.endt,'string',num2str(et));
        set(handles.redr,'string',num2str(Rr));
        set(handles.bluer,'string',num2str(Rb));
%         if x(end)==0
         plot([0,et],[x0,Rr],'r-');
         hold on
         plot([0,et],[y0,Rb],'b-');
         hold off
         grid on
         grid minor
    case 2
      if a*y0^2>b*x0^2
          w='蓝方';
          Rb=sqrt(y0^2-(b/a)*x0^2)
          Rr=0;
          et=log((sqrt(b)*x0+sqrt(a)*y0)/(-sqrt(b)*x0+sqrt(a)*y0))/2/sqrt(a*b);
      end
       if a*y0^2<b*x0^2
          w='红方';
          Rr=sqrt(x0^2-(a/b)*y0^2)
          Rb=0;
          et=log((sqrt(b)*x0+sqrt(a)*y0)/(sqrt(b)*x0-sqrt(a)*y0))/2/sqrt(a*b);
       end
       set(handles.winp,'string',w);%显示计算结果
        %fh = @(x,y) a.*x.^2 - b.*y.^2 - a.*y0.^2+b.*x0.^2;
        %ezplot(@(x,y)myfun(x,y,x0,a,y0,b),[0,x0]);
        t=[0:0.1:et];
        ab=sqrt(a*b);
        x=x0*cosh(ab*t)-(sqrt(a/b)*y0)*sinh(ab*t);
        y=y0*cosh(ab*t)-(sqrt(b/a)*x0)*sinh(ab*t);
        plot(t,x,'r-');
        hold on
        plot(t,y,'b-');
        hold off
        grid minor
%         bar(1:.5:10);
%     case 4
%         plot(membrane);
%     case 5
%         surf(peaks);
end
function FileMenu_Callback(hObject, eventdata, handles)
% hObject    handle to FileMenu (see GCBO)
function OpenMenuItem_Callback(hObject, eventdata, handles)
% hObject    handle to OpenMenuItem (see GCBO)
file = uigetfile('*.fig');
if ~isequal(file, 0)
    open(file);
end
function PrintMenuItem_Callback(hObject, eventdata, handles)
% hObject    handle to PrintMenuItem (see GCBO)
printdlg(handles.figure1)
function CloseMenuItem_Callback(hObject, eventdata, handles)
% hObject    handle to CloseMenuItem (see GCBO)
selection = questdlg(['Close ' get(handles.figure1,'Name') '?'],...
                     ['Close ' get(handles.figure1,'Name') '...'],...
                     'Yes','No','Yes');
if strcmp(selection,'No')
    return;
end
delete(handles.figure1)
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
if (double(get(hObject,'Value')==2))
     set(handles.text6,'ForegroundColor','yellow');
end
% Hints: contents = get(hObject,'String') returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
     set(hObject,'BackgroundColor','blue');
end
set(hObject, 'String', {'lanchester线性律', 'lanchester平方律', });%选择菜单的设计
function red1_Callback(hObject, eventdata, handles)
% hObject    handle to red1 (see GCBO)
% Hints: get(hObject,'String') returns contents of red1 as text
%        str2double(get(hObject,'String')) returns contents of red1 as a double
function red1_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
    set(hObject,'BackgroundColor','white');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/114259341
