【图像处理】基于matlab GUI图像全局+局部美化【含Matlab源码 1461期】
海神之光 发表于 2022/05/29 23:23:43 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【图像处理】基于matlab GUI图像全局+局部美化...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【图像处理】基于matlab GUI图像全局+局部美化【含Matlab源码 1461期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、数字图像处理简介
图像处理基础教程链接
1 【基础教程】基于matlab图像处理(表示方法+数据结构+基本格式+类型转换+读取+点运算+代数运算)【含Matlab源码 834期】
2 【基础教程】基于matlab图像处理(读写+显示+运算+转换+变换+增强+滤波+分析+统计)【含Matlab源码 144期】
3 【基础教程】基于matlab图像增强+复原+分割【含Matlab源码 056期】
三、部分源代码
function varargout = Turbo(varargin)
%        set(handles.pushbutton25,'String',round(10*pos)/10);
%TURBO M-file for Turbo.fig
%      TURBO, by itself, creates a new TURBO or raises the existing
%      singleton*.
%      H = TURBO returns the handle to a new TURBO or the handle to
%      TURBO('Property','Value',...) creates a new TURBO using the
%      given property value pairs. Unrecognized properties are passed via
%      varargin to Turbo_OpeningFcn.  This calling syntax produces a
%      warning when there is an existing singleton*.
%      TURBO('CALLBACK') and TURBO('CALLBACK',hObject,...) call the
%      local function named CALLBACK in TURBO.M with the given input
%      arguments.
% Edit the above text_set to modify the response to help Turbo
% Last Modified by GUIDE v2.5 16-Oct-2021 15:33:05
gui_Singleton = 1;
                   'gui_OpeningFcn', @Turbo_OpeningFcn, ...
                   'gui_OutputFcn',  @Turbo_OutputFcn, ...
                   'gui_LayoutFcn',  [], ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before Turbo is made visible.
function Turbo_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   unrecognized PropertyName/PropertyValue pairs from the
%            command line (see VARARGIN)
% Choose default command line output for Turbo
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes Turbo wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = Turbo_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in open.
function open_Callback(hObject, eventdata, handles)
% hObject    handle to open (see GCBO)
[FileName,PathName,FilterIndex]=uigetfile({'*.jpg';'*.bmp';'*.png';'*.gif'},'请选择文件');
if FilterIndex==1
    data=imread([PathName,FileName]);
    [widch,height,dim] = size(data);
    set(handles.open_path,'string',[PathName,FileName]);
    set(handles.pic_size,'UserData',[widch,height,dim]);
%    set(handles.pic_size_tem,'UserData',[widch,height,dim]);
  %  set(handles.pic_size_backup,'UserData',[widch,height,dim]);
    set(hObject,'UserData',data);
    set(handles.Reset,'UserData',data);
    str_jpg = dir([PathName '\*.jpg']);  % 自动读取上一张图片、下一张图片
    str_bmp = dir([PathName '\*.bmp']);
    str_png = dir([PathName '\*.png']);
    str_gif = dir([PathName '\*.gif']);
    pic_str =[str_jpg;str_bmp;str_png;str_gif];
    pic_cell = struct2cell(pic_str);
    pic_name = pic_cell(1,:);
    [~,pic_index] = ismember('lena.jpg',pic_name);
    set(handles.pic_pre,'UserData',pic_name);
    set(handles.pic_next,'UserData',pic_index);
    set(handles.Help,'UserData',PathName);
    imshow(data);
else
end
function open_path_Callback(hObject, eventdata, handles)
% hObject    handle to open_path (see GCBO)
% Hints: get(hObject,'String') returns contents of open_path as text_set
%        str2double(get(hObject,'String')) returns contents of open_path as a double
% --- Executes during object creation, after setting all properties.
function open_path_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in save.
function save_Callback(hObject, eventdata, handles)
% hObject    handle to save (see GCBO)
data=get(handles.open,'UserData');
[FileName,PathName,FilterIndex]=uiputfile({'*.jpg';'*.bmp';'*.png';},'保存文件','new_figure');
if FilterIndex ==1
    set(handles.save_path,'string',[PathName,FileName]);
    imwrite(data,[PathName,FileName]);
else
end
function save_path_Callback(hObject, eventdata, handles)
% hObject    handle to save_path (see GCBO)
% Hints: get(hObject,'String') returns contents of save_path as text_set
%        str2double(get(hObject,'String')) returns contents of save_path as a double
function save_path_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in Help.
function Help_Callback(hObject, eventdata, handles)
% hObject    handle to Help (see GCBO)
help_path = get(handles.Help,'UserData');
help_pdf = 'Turbo软件使用说明.pdf';
open([help_path,help_pdf]);
% --- Executes on button press in pic_pre.
function pic_pre_Callback(hObject, eventdata, handles)
% hObject    handle to pic_pre (see GCBO)
  pic_path = get(handles.Help,'UserData');
  pic_name =  get(hObject,'UserData');
  pic_index  = get(handles.pic_next,'UserData');
  if pic_index == 1
      msgbox('第一张')
  else
    pic_index = pic_index - 1;
    data=imread([pic_path,pic_name{1,pic_index}]);
    set(handles.open_path,'string',[pic_path,pic_name{1,pic_index}]);
    set(handles.open,'UserData',data);
    imshow(data);
  end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]陈浩,方勇,朱大洲,王成,陈子龙.基于蚁群算法的玉米植株热红外图像边缘检测[J].农机化研究. 2015,37(06)
原文链接:qq912100926.blog.csdn.net/article/details/120990272
