【物理应用】基于matlab双目视觉三维重建【含Matlab源码 1781期】
海神之光 发表于 2022/05/30 01:02:42 2022/05/30
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【物理应用】基于matlab双目视觉三维重建【含Matlab源码 1781期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%% Clean the slate
% The demo here in the main.html document can be run directly from main.m
% In this section the memory is cleared, some parameters are set, and the
% original images are loaded and displayed.
close all
clear
clc
% Setting up parameters and filenames
params.VERBOSE          = 1;                    %Get more plots out (True or False)
params.PLANE            = 3;                    %Which plane of the RGB is of interest to us for opperations on a single plane
params.BLACK_BACKGROUND = 1;                    %Images have a black background (True or False)
params.map                      = copper(256);  %Set colormap to something that is similar to wood
params.number_angular_divisions = 2^7;          %Powers of two are faster FFT
params.number_radial_divisions  = 40;           %Arbitrary constant
base_filename = 'dowel01.jpg';                  %Filename of non-moving image
move_filename = 'dowel02.jpg';                  %Filename of image that will move to the base image
base_image = imread(base_filename);    %reads in the image
move_image = imread(move_filename);    %reads in the image
% Data visualization.
subplot(1,2,1)
subimage(base_image);
title('Base image')
subplot(1,2,2)
subimage(move_image);
title('Image to move')
set (gcf, 'color', 'w')
%% Correct the X and Y displacements
% The two images are displaced from each other in the X and Y direcions.
% First the X and Y direction will be corrected by lining up the centroids
% of the two images.
% Method: First mask the image from background then find
% centroid of the image. Finally center the image based
% on its centroid.
base_plane_of_interest              = base_image(:,:,params.PLANE);
%Must use a single layer grayscale for most operations.  Blue plane is best
%contrast for these images
base_bw_plane_of_interest           = im2bw(base_plane_of_interest, graythresh(base_plane_of_interest));
%Turn to binary based on threshold gotten from graythresh
base_plane_of_interest_segmented    = bwmorph(base_bw_plane_of_interest, 'open');
%morphology
base_binary_mask                    = imfill (base_plane_of_interest_segmented, 'holes');
%fill it in
% Get some data about the new region
base_properties                     = regionprops(real(base_binary_mask),'all');
base_centroid_row                   = round(base_properties.Centroid(2));
base_centroid_col                   = round(base_properties.Centroid(1));
% Place a dot at the centroid, one for each layer
base_image(base_centroid_row, base_centroid_col, 1) = 255;
base_image(base_centroid_row, base_centroid_col, 2) = 255;
base_image(base_centroid_row, base_centroid_col, 3) = 255;
% Nice to have image be 0dd number of pixels in each diension
base_image       = make_odd_by_odd(base_image);
base_binary_mask = make_odd_by_odd(base_binary_mask);
% Grab the new size
[base_num_rows, base_num_cols, base_num_layers] = size(base_image);
% Where is the center of the image?
base_goal_row   = (base_num_rows - 1) / 2 + 1;
base_goal_col   = (base_num_cols - 1) / 2 + 1;
% how much do I need to move to center this?
base_delta_rows = base_goal_row - base_centroid_row;
base_delta_cols = base_goal_col - base_centroid_col;
%shift the images to be centered
base_image       = circshift(base_image      , [base_delta_rows, base_delta_cols]);
base_binary_mask = circshift(base_binary_mask, [base_delta_rows, base_delta_cols]);
% Same thing for the second image.  In production code this would be in
% a function, but this script was made for seminar presentation where all
% the code should be visible.
% Begin repeated code -------------------------------------
move_plane_of_interest              = move_image(:,:,params.PLANE);
move_bw_plane_of_interest           = im2bw(move_plane_of_interest, graythresh(move_plane_of_interest));
move_plane_of_interest_segmented    = bwmorph(move_bw_plane_of_interest, 'open');
move_binary_mask                    = imfill (move_plane_of_interest_segmented, 'holes');
move_properties                     = regionprops(real(move_binary_mask),'all');
move_centroid_row                   = round(move_properties.Centroid(2));
move_centroid_col                   = round(move_properties.Centroid(1));
move_image(move_centroid_row, move_centroid_col, 1) = 255;
move_image(move_centroid_row, move_centroid_col, 2) = 255;
move_image(move_centroid_row, move_centroid_col, 3) = 255;
move_image                          = make_odd_by_odd(move_image);
move_binary_mask                    = make_odd_by_odd(move_binary_mask);
[move_num_rows, move_num_cols, move_num_layers]     = size(move_image);
move_goal_row                       = (move_num_rows - 1) / 2 + 1;
move_goal_col                       = (move_num_cols - 1) / 2 + 1;
move_delta_rows                     = move_goal_row - move_centroid_row;
move_delta_cols                     = move_goal_col - move_centroid_col;
move_image                          = circshift(move_image      , [move_delta_rows, move_delta_cols]);
move_binary_mask                    = circshift(move_binary_mask, [move_delta_rows, move_delta_cols]);
% End of repeated code -------------------------------------
subplot(1,2,1)
title('Centered base image')
subplot(1,2,2)
title('Centered moveable image')
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/123512763
