【图像分割】基于matlab直觉模糊C均值聚类图像分割IFCM【含Matlab源码 120期】
海神之光 发表于 2022/05/29 04:41:08 2022/05/29
【摘要】 一、图像分割简介 理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】 二、部分源代码 clear close all clc clear close all...
一、图像分割简介
二、部分源代码
clear
close all
clc
clear
close all
clc
%% %%%%%%%%%%%%%%%图像%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
 I=imread('3096.jpg');
if size(I,3) == 3
   I=rgb2gray(I);
else
end
figure;imshow(I);title('(a)原始图像');imwrite(I,'1.tiff','tiff','Resolution',300);%保存为tif
%I=I;%不加噪声
% I=imnoise(I,'speckle',deta_2);
I=imnoise(I,'salt & pepper',0.05); %加噪图椒盐噪声
% I=imnoise(I,'gaussian',0,0.01); % 加高斯噪声
figure;imshow(I);title('(b)加噪图像');imwrite(I,['2.','.tiff'],'tiff','Resolution',300);%保存为tif
[m,n]=size(I);
% k=4;
k=2;
r=3;
m_index=2;
beta=6;
neighbor=3;%3*3邻域去噪
lamda_s_enfcm=3;%s参数
I=im2double(I);
I4 = I(:);  %% 将图像灰度按列排列
%% ------------------------ ifcm------------------------
ifcm_label=zeros(m*n,1);
t=cputime;
tic;
[O2, U2, obj_fcn2] = ifcm(I4, k);
toc;
time_fcm_spatial_mean=cputime-t;
maxU2 = max(U2);   %隶属度最大
for j=1:k
    index = find(U2(j, :) == maxU2);  %隶属度最大对应的像素位置
   ifcm_label(index) = j;
end
labels2=reshape(ifcm_label,[m n]);
%显示聚类分割图
labels2(find(labels2==1))=0;
labels2(find(labels2==2))=255;
labels2(find(labels2==3))=125;
labels2(find(labels2==4))=180;
labels2=uint8(labels2);
% figure;imshow(labels2,[]);title('(c)聚类分割图');imwrite(labels2,'3.jpg');imwrite(labels2,'33.png')%保存为jpg
imwrite(labels2,['3.1.','.tiff'],'tiff','Resolution',300);%保存为tif
function [center, U, obj_fcn] = ifcm(data,cluster_n)
if nargin ~= 2 & nargin ~= 3,
	error('Too many or too few input arguments!');
end
data_n = size(data, 1);
in_n = size(data, 2);
% Change the following to set default options
default_options = [2;	% exponent for the partition matrix U
		100;	% max. number of iteration
		1e-5;	% min. amount of improvement
		1];	% info display during iteration
if nargin == 2,
	options = default_options;
else
	% If "options" is not fully specified, pad it with default values.
	if length(options) < 4,
		tmp = default_options;
		tmp(1:length(options)) = options;
		options = tmp;
	end
	% If some entries of "options" are nan's, replace them with defaults.
	nan_index = find(isnan(options)==1);
	options(nan_index) = default_options(nan_index);
	if options(1) <= 1,
		error('The exponent should be greater than 1!');
	end
end
expo = options(1);		% Exponent for U
max_iter = options(2);		% Max. iteration
min_impro = options(3);		% Min. improvement
display = options(4);		% Display info or not
obj_fcn = zeros(max_iter, 1);	% Array for objective function
%U = initfcm(cluster_n, data_n);			% Initial fuzzy partition
center= initifcmv(cluster_n);            %初始化聚类中心
[Miuij,Vij,Paiij]=initifcmmvp(data);
for i = 1:max_iter,
    [U, center, obj_fcn(i)] = ifcm_step(data, center, cluster_n, expo, Miuij,Vij,Paiij);
	if display,
		fprintf('Iteration count = %d, obj. fcn = %f\n', i, obj_fcn(i));
	end
	% check termination condition
	if i>1
% 		if abs(obj_fcn(i) - obj_fcn(i-1)) < min_impro, break; end,
 %        if norm(old_U-U,2) < min_impro, break; end,
%        if norm(old_U-U,'fro') < min_impro, break; end,
       if norm(old_center-center,2) < min_impro, break; end,
       % (old_center-center).^2
    end
    old_U = U;
    old_center = center;
end
% iter_n = i;	% Actual number of iterations
% % obj_fcn(iter_n+1:max_iter) = [];
% mf = old_U.^expo;       % 隶属度矩阵进行指数运算结果
% dist = distfcm(old_center, data);       % 计算距离矩阵
% obj_fcn = sum(sum((dist.^2).*mf));  % 计算目标函数值
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/112907955
