【SVM分类】基于matlab蝙蝠算法优化SVM分类【含Matlab源码 141期】
海神之光 发表于 2022/05/29 06:05:03 2022/05/29
【摘要】 一、简介 二、部分源代码 tic % 计时器 %% 清空环境变量 close all clear clc %format compact load('ISSL-Isomap.mat') % loa...
一、简介
二、部分源代码
tic % 计时器
%% 清空环境变量
close all
clear
clc
%format compact
%  load CMPE原始
%  mappedX=X;
%% 数据提取
zc=mappedX(1:60,:);%特征输入
lie=mappedX(61:120,:);
mo=mappedX(121:180,:);
que=mappedX(181:240,:);
duan=mappedX(241:300,:);
mm=size(zc,1);
nn=20;
a=ones(mm,1);%行为总体样本数
b=2*ones(mm,1);
c=3*ones(mm,1);
d=4*ones(mm,1);
f=5*ones(mm,1);
n1=randperm(size(zc,1));
n2=randperm(size(lie,1));
n3=randperm(size(mo,1));
n4=randperm(size(que,1));
n5=randperm(size(duan,1));
train_wine = [zc(n1(1:nn),:);lie(n2(1:nn),:);mo(n3(1:nn),:);que(n4(1:nn),:);duan(n5(1:nn),:)];
% 相应的训练集的标签也要分离出来
train_wine_labels = [a(1:nn,:);b(1:nn,:);c(1:nn,:);d(1:nn,:);f(1:nn,:)];
% 将第一类的31-59,第二类的96-130,第三类的154-178做为测试集
test_wine = [zc(n1((nn+1):mm),:);lie(n2((nn+1):mm),:);mo(n3((nn+1):mm),:);que(n4((nn+1):mm),:);duan(n5((nn+1):mm),:)];
% 相应的测试集的标签也要分离出来
test_wine_labels = [a((nn+1):mm,:);b((nn+1):mm,:);c((nn+1):mm,:);d((nn+1):mm,:);f((nn+1):mm,:)];
%% 数据预处理
% 数据预处理,将训练集和测试集归一化到[0,1]区间
[mtrain,ntrain] = size(train_wine);
[mtest,ntest] = size(test_wine);
dataset = [train_wine;test_wine];
% mapminmax为MATLAB自带的归一化函数
[dataset_scale,ps] = mapminmax(dataset',0,1);
dataset_scale = dataset_scale';
train_wine = dataset_scale(1:mtrain,:);
test_wine = dataset_scale( (mtrain+1):(mtrain+mtest),: );
%% Default parameters 默认参数
n=10;      % Population size, typically10 to 40
N_gen=150;  % Number of generations
A=0.5;      % Loudness  (constant or decreasing)
r=0.5;      % Pulse rate (constant or decreasing)
% This frequency range determines the scalings
% You should change these values if necessary
Qmin=0;         % Frequency minimum
Qmax=2;         % Frequency maximum
% Iteration parameters
N_iter=0;       % Total number of function evaluations   %这是什么意思???
% Dimension of the search variables
d=2;           % Number of dimensions
% Lower limit/bounds/ a vector
Lb=[0.01,0.01]; % 参数取值下界
Ub=[100,100]; % 参数取值上界
% Initializing arrays
Q=zeros(n,1);   % Frequency
v=zeros(n,d);   % Velocities
% Initialize the population/solutions
% Output/display
disp(['Number of evaluations: ',num2str(N_iter)]);
disp(['Best =',num2str(best),' fmin=',num2str(fmin)]);
%% 利用最佳的参数进行SVM网络训练
cmd_gwosvm = ['-c ',num2str(best(:,1)),' -g ',num2str(best(:,2))];
model_gwosvm = svmtrain(train_wine_labels,train_wine,cmd_gwosvm);
%% SVM网络预测
[predict_label] = svmpredict(test_wine_labels,test_wine,model_gwosvm);
total = length(test_wine_labels);% 打印测试集分类准确率
right = length(find(predict_label == test_wine_labels));
Accuracy=right/total;
% disp('打印测试集分类准确率');
% str = sprintf( 'Accuracy = %g%% (%d/%d)',accuracy(1),right,total);
% disp(str);
%% 结果分析
% 测试集的实际分类和预测分类图
figure;
hold on;
plot(test_wine_labels,'o');
plot(predict_label,'r*');
xlabel('测试集样本','FontSize',12);
ylabel('类别标签','FontSize',12);
legend('实际测试集分类','预测测试集分类');
title('测试集的实际分类和预测分类图','FontSize',12);
grid on
snapnow
figure
plot(1:N_gen,AAA);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
[3]周品.MATLAB 神经网络设计与应用[M].清华大学出版社,2013.
[4]陈明.MATLAB神经网络原理与实例精解[M].清华大学出版社,2013.
[5]方清城.MATLAB R2016a神经网络设计与应用28个案例分析[M].清华大学出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/112985578
