【图像去噪】基于matlab即插即用法图像去噪【含Matlab源码 152期】
海神之光 发表于 2022/05/29 03:52:59 2022/05/29
【摘要】 一、简介 理论知识参考文献:基于Retinex和ADMM优化的水下光照不均匀图像增强算法 二、部分源代码 function out = PlugPlayADMM_deblur(y,h,lambda,...
一、简介
二、部分源代码
function out = PlugPlayADMM_deblur(y,h,lambda,method,opts)
%out = PlugPlayADMM_deblur(y,h,lambda,method,opts)
%deblurs image y by solving the ADMM:
%inversion step: x=argmin_x(||Ax-y||^2+rho/2||x-(v-u)||^2)
%denoising step: v=Denoise(x+u)
%      update u: u=u+(x-v)
%Input:           y    -  the observed gray scale image
%                 h    -  blur kernel
%              lambda  -  regularization parameter
%              method  -  denoiser, e.g., 'BM3D'
%       opts.rho       -  internal parameter of ADMM {1}
%       opts.gamma     -  parameter for updating rho {1}
%       opts.maxitr    -  maximum number of iterations for ADMM {20}
%       opts.tol       -  tolerance level for residual {1e-4}
%       ** default values of opts are given in {}.
%Output:          out  -  recovered gray scale image
%Xiran Wang and Stanley Chan
%Copyright 2016
%Purdue University, West Lafayette, In, USA.
% Check inputs
if nargin<4
    error('not enough input, try again \n');
elseif nargin==4
    opts = [];
end
% Check defaults
if ~isfield(opts,'rho')
    opts.rho = 1;
end
if ~isfield(opts,'max_itr')
    opts.max_itr = 20;
end
if ~isfield(opts,'tol')
    opts.tol = 1e-4;
end
if ~isfield(opts,'gamma')
    opts.gamma=1;
end
if ~isfield(opts,'print')
    opts.print = false;
end
% set parameters
max_itr   = opts.max_itr;
tol       = opts.tol;
gamma     = opts.gamma;
rho       = opts.rho;
%initialize variables
dim         = size(y);
N           = dim(1)*dim(2);
Hty         = imfilter(y,h,'circular');
eigHtH      = abs(fftn(h, dim)).^2;
residual    = inf;
%set function handle for denoiser
switch method
    case 'BM3D'
        denoise=@wrapper_BM3D;
    case 'TV'
        denoise=@wrapper_TV;
    case 'NLM'
        denoise=@wrapper_NLM;
    case 'RF'
        denoise=@wrapper_RF;
    otherwise
        error('unknown denoiser \n');
end
% main loop
if opts.print==true
    fprintf('Plug-and-Play ADMM --- Deblurring \n');
    fprintf('Denoiser = %s \n\n', method);
    fprintf('itr \t ||x-xold|| \t ||v-vold|| \t ||u-uold|| \n');
end
itr = 1;
while(residual>tol&&itr<=max_itr)
    %store x, v, u from previous iteration for psnr residual calculation
    x_old = x;
    v_old = v;
    u_old = u;
    %inversion step
    xtilde = v-u;
    rhs    = fftn(Hty+rho*xtilde,dim);
    x      = real(ifftn(rhs./(eigHtH+rho),dim));
    %denoising step
    vtilde = x+u;
    vtilde = proj(vtilde);
    sigma  = sqrt(lambda/rho);
    v      = denoise(vtilde,sigma);
    %update langrangian multiplier
    u      = u + (x-v);
    %update rho
    rho = rho*gamma;
    %calculate residual
    residualx = (1/sqrt(N))*(sqrt(sum(sum((x-x_old).^2))));
    residualv = (1/sqrt(N))*(sqrt(sum(sum((v-v_old).^2))));
    residualu = (1/sqrt(N))*(sqrt(sum(sum((u-u_old).^2))));
    residual = residualx + residualv + residualu;
    if opts.print==true
        fprintf('%3g \t %3.5e \t %3.5e \t %3.5e \n', itr, residualx, residualv, residualu);
    end
    itr = itr+1;
end
out = v;
end
function y = afun(x,transp_flag,h,dim)
% Example of the A matrix
% This example illustrates how to construct the A matrix
% for deblurring problem. The function executes the operations of
% A*x and A'*x
% Stanley Chan
% Purdue University
% Nov 24, 2016
rows = dim(1);
cols = dim(2);
if strcmp(transp_flag,'transp')         % y = A'*x
    x = reshape(x,[rows,cols]);
    y = imfilter(x,rot90(h,2),'circular');
    y = y(:);
elseif strcmp(transp_flag,'notransp')   % y = A*x
    y = imfilter(x,h,'circular');
    y = y(:);
end
end
function out = wrapper_NLM(in,sigma)
% out = wrapper_NLM(in,sigma)
% performs non-local means denoising
% Require NLM package
% Download:
% http://www.ipol.im/pub/art/2011/bcm_nlm/
% Xiran Wang and Stanley Chan
% Copyright 2016
% Purdue University, West Lafayette, In, USA.
Options.filterstrength=sigma;
out = NLMF(in,Options);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]刘卫东,李吉玉,张文博,李乐.基于Retinex和ADMM优化的水下光照不均匀图像增强算法[J].西北工业大学学报. 2021,39(04)
原文链接:qq912100926.blog.csdn.net/article/details/113028098
