【花式】基于matlab花圣诞树【含Matlab源码 001期】
海神之光 发表于 2022/05/29 04:11:26 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源: 【花式】基于matlab花圣诞树【含Matlab源码 001期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function christmas
% Anselm Ivanovas, anselm.ivanovas@student.unisg.ch
%Basically just a nice plot for some christmas fun.
%3D Plot of a hhristmas tree with some presents and snow
%% setup
snow=800;     % number of snow flakes [0 .. 5000]
%% draw tree
h=0:0.2:25; %vertical grid
[X,Y,Z] = cylinder(tree(h)); %produce a tree formed cylinder
Z=Z*25; %scale to the right heigth
%Add some diffusion to the surface of the tree to make it look more real
treeDiffusion=rand(126,21)-0.5;%some horizontal diffusion data
%add diffusion to the grid points
for cnt1=1:21
    for cnt2=16:126%starting above the trunk
        %get the angle to always diffuse in direction of the radius
        angle=atan(Y(cnt2,cnt1)/X(cnt2,cnt1));
        %split the diffusion in the two coordinates, depending on the angle
        X(cnt2,cnt1)=X(cnt2,cnt1)+cos(angle)*treeDiffusion(cnt2,cnt1);
        Y(cnt2,cnt1)=Y(cnt2,cnt1)+sin(angle)*treeDiffusion(cnt2,cnt1);
        %some Vertical diffusion for each point
        Z(cnt2,cnt1)=Z(cnt2,cnt1)+(rand-0.5)*0.5;
    end
end
%draw the tree
surfl(X,Y,Z,'light')
%% View and format
%Use as nice green color map (darker at the bottom, lighter at the top)
r=(0.0430:(0.2061/50):0.2491)';%red component
g=(0.2969:(0.4012/50):0.6981)';%green component
b=(0.0625:(0.2696/50):0.3321)';%blue component
map=[r,g,b];%join in a map
for cnt=1:6
    %change the lower part to brown for the trunk
    map(cnt,:)=[77,63,5]/265;
end
colormap(map)%set the map
view([-37.5,4])%Change the view to see a little more of the Actual 3D tree
lighting phong %some nice lighting
shading interp %remove grid and smoothen the surface color
axis equal %takes care of display in the right proportion
axis([-10 10 -10 10 0 30]) %give some more axis space (for the snow later)
axis off %but don't show axis
hold on %to draw the rest
title('HAPPY HOLIDAYS')%self explaining
%% Presents
%Draw some presents around the tree (each with random color)
drawPresent(2,-4,0,3,3,2);
drawPresent(-4,3,0,2,3,1.5);
drawPresent(5,3,0,4,3,3);
drawPresent(-14,-5,0,6,3,1);
drawPresent(-9,-10,0,2,2,2);
drawPresent(0,4,0,4,3,3);
drawPresent(-6,-13,0,3,3,3);
%% Snow
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
三、运行结果
四、备注
版本:2014a
原文链接:qq912100926.blog.csdn.net/article/details/113088538
