【人脸识别】基于matlab GUI LPP人脸特征提取【含Matlab源码 1491期】
海神之光 发表于 2022/05/29 04:23:59 2022/05/29
【摘要】 一、简介 理论知识参考文献:基于局部特征提取人脸识别方法优化研究 二、部分源代码 function varargout = spectacles_lpp_classification(varargi...
一、简介
二、部分源代码
function varargout = spectacles_lpp_classification(varargin)
% SPECTACLES_LPP_CLASSIFICATION MATLAB code for spectacles_lpp_classification.fig
%      SPECTACLES_LPP_CLASSIFICATION, by itself, creates a new SPECTACLES_LPP_CLASSIFICATION or raises the existing
%      singleton*.
%      H = SPECTACLES_LPP_CLASSIFICATION returns the handle to a new SPECTACLES_LPP_CLASSIFICATION or the handle to
%      SPECTACLES_LPP_CLASSIFICATION('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in SPECTACLES_LPP_CLASSIFICATION.M with the given input arguments.
%      SPECTACLES_LPP_CLASSIFICATION('Property','Value',...) creates a new SPECTACLES_LPP_CLASSIFICATION or raises the
%      applied to the GUI before spectacles_lpp_classification_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to spectacles_lpp_classification_OpeningFcn via varargin.
% Edit the above text to modify the response to help spectacles_lpp_classification
% Last Modified by GUIDE v2.5 25-May-2021 21:40:39
gui_Singleton = 1;
                   'gui_OpeningFcn', @spectacles_lpp_classification_OpeningFcn, ...
                   'gui_OutputFcn',  @spectacles_lpp_classification_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before spectacles_lpp_classification is made visible.
function spectacles_lpp_classification_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to spectacles_lpp_classification (see VARARGIN)
% Choose default command line output for spectacles_lpp_classification
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes spectacles_lpp_classification wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = spectacles_lpp_classification_OutputFcn(hObject, eventdata, handles)
% --- Executes on selection change in lstPositive.
function lstPositive_Callback(hObject, eventdata, handles)
% hObject    handle to lstPositive (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns lstPositive contents as cell array
%        contents{get(hObject,'Value')} returns selected item from lstPositive
displayCurrentItem(hObject,handles)
% --- Executes during object creation, after setting all properties.
function lstPositive_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: listbox controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function decision = getDecision(current_image)
global projected_data Positive_mean sgn;
for i = 1:length(current_image)
    decision(i) = (sgn(Positive_mean(1),Positive_mean(2))* ...
        sgn(projected_data(current_image(i),1),projected_data( ...
        current_image(i),2))>0);
end
function displayCurrentItem(hObject,handles)
global dat_a_ height width projected_data;
contents = cellstr(get(hObject,'String'));
current_image = str2double(contents{get(hObject,'Value')});
datalet = dat_a_(current_image,1:end-1);
img = uint8(reshape(datalet,height,width));
imshow(img,'Parent',handles.plotArea2);
if (~isempty(projected_data))
    h = get(handles.plotArea1,'Children');
    allAvailableTypes = get(h,'type');
    [tf,loc]=ismember('text',allAvailableTypes);
    if(~tf)
        text(projected_data(current_image,1), ...
            projected_data(current_image,2), num2str(current_image), ...
            'Parent',handles.plotArea1,'FontWeight','bold');
    else
        set(h(loc),'Position',[projected_data(current_image,1), ...
            projected_data(current_image,2)],'String', ...
            num2str(current_image));
    end
    if(getDecision(current_image))
        set(handles.result,'String','With Spectacles');
    else
        set(handles.result,'String','Without Spectacles');
    end
end
% --- Executes on selection change in lstTest.
function lstTest_Callback(hObject, eventdata, handles)
% hObject    handle to lstTest (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns lstTest contents as cell array
%        contents{get(hObject,'Value')} returns selected item from lstTest
function lstTest_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global dat_a_ Name_Database height width projected_data;
dat_a_=[];
Name_Database=[];
height=[];
width=[];
projected_data=[];
% Loading the database file
filename = uigetfile('*.mat', 'Select database file');
load(filename);
dat_a_ = data;
%Check if it is loaded correctly
if exist('Database_name','var')
    Name_Database = Database_name;
    % Get the number of elements loaded
    m = size(dat_a_,1);
    pos_count = sum(dat_a_(:,end));
    neg_count = m - pos_count;
    % Show a notification of how many elements are loaded
    set(handles.txtloadPrompt,'String',sprintf('%d items loaded',m));
    % Calculating amount of training data
    % The rule of selection: See whether the positive or the
    % negative samples are fewer in amount. Take half of the data from the
    % fewer class and an equal number of data from the other class. So,
    % the total number of training data = 2 * (1/2) * min(amount of data in
    % class with sunglass, amount of data in class without sunglass)
    training_size = min(pos_count,neg_count);
    test_size = m - training_size;
    set(handles.txtSizeTraining,'String',num2str(training_size));
    set(handles.txtSizeTesting,'String',num2str(test_size));
else
    msgbox('The database could not be loaded');
end
function txtSizeTraining_Callback(hObject, eventdata, handles)
% hObject    handle to txtSizeTraining (see GCBO)
% Hints: get(hObject,'String') returns contents of txtSizeTraining as text
%        str2double(get(hObject,'String')) returns contents of txtSizeTraining as a double
global dat_a_;
m = size(dat_a_,1);
m_n = str2double(get(hObject, 'String'));
set(handles.txtSizeTesting,'String',m - m_n);
function txtSizeTraining_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
end
function txtSizeTesting_Callback(hObject, eventdata, handles)
% hObject    handle to txtSizeTesting (see GCBO)
% Hints: get(hObject,'String') returns contents of txtSizeTesting as text
%        str2double(get(hObject,'String')) returns contents of txtSizeTesting as a double
function txtSizeTesting_CreateFcn(hObject, eventdata, handles)
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]李奇杰,杨洪臣.基于局部特征提取人脸识别方法优化研究[J].金融科技时代. 2021,29(04)
原文链接:qq912100926.blog.csdn.net/article/details/113694525
