【光学】基于matlab单缝衍射【含Matlab源码 342期】
海神之光 发表于 2022/05/29 05:59:34 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【光学】基于matlab单缝衍射【含Matlab源码 342期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、简介
三、部分源代码
unction varargout = yansheGUI(varargin)
% YANSHEGUI M-file for yansheGUI.fig
%      YANSHEGUI, by itself, creates a new YANSHEGUI or raises the existing
%      singleton*.
%      H = YANSHEGUI returns the handle to a new YANSHEGUI or the handle to
%      YANSHEGUI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in YANSHEGUI.M with the given input arguments.
%      YANSHEGUI('Property','Value',...) creates a new YANSHEGUI or raises the
%      applied to the GUI before yansheGUI_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to yansheGUI_OpeningFcn via varargin.
% Edit the above text to modify the response to help yansheGUI
% Last Modified by GUIDE v2.5 23-Mar-2013 14:24:59
gui_Singleton = 1;
                   'gui_OpeningFcn', @yansheGUI_OpeningFcn, ...
                   'gui_OutputFcn',  @yansheGUI_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before yansheGUI is made visible.
function yansheGUI_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to yansheGUI (see VARARGIN)
% Choose default command line output for yansheGUI
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes yansheGUI wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = yansheGUI_OutputFcn(hObject, eventdata, handles)
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/113872722
