【数学建模】基于matlab GUI建立三维模型【含Matlab源码 243期】
海神之光 发表于 2022/05/29 04:10:05 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab GUI建立三维模型【含Matlab源码 243期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = GUI_rec(varargin)
% GUI_REC MATLAB code for GUI_rec.fig
%      GUI_REC, by itself, creates a new GUI_REC or raises the existing
%      singleton*.
%      H = GUI_REC returns the handle to a new GUI_REC or the handle to
%      GUI_REC('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in GUI_REC.M with the given input arguments.
%      GUI_REC('Property','Value',...) creates a new GUI_REC or raises the
%      applied to the GUI before GUI_rec_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to GUI_rec_OpeningFcn via varargin.
% Edit the above text to modify the response to help GUI_rec
% Last Modified by GUIDE v2.5 01-May-2021 21:58:24
gui_Singleton = 1;
                   'gui_OpeningFcn', @GUI_rec_OpeningFcn, ...
                   'gui_OutputFcn',  @GUI_rec_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before GUI_rec is made visible.
function GUI_rec_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to GUI_rec (see VARARGIN)
% Choose default command line output for GUI_rec
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes GUI_rec wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = GUI_rec_OutputFcn(hObject, eventdata, handles)
function edit2_Callback(hObject, eventdata, handles)
% hObject    handle to edit2 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit2 as text
%        str2double(get(hObject,'String')) returns contents of edit2 as a double
% --- Executes during object creation, after setting all properties.
function edit2_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function edit3_Callback(hObject, eventdata, handles)
% hObject    handle to edit3 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit3 as text
%        str2double(get(hObject,'String')) returns contents of edit3 as a double
function edit3_CreateFcn(hObject, eventdata, handles)
end
function edit4_Callback(hObject, eventdata, handles)
% hObject    handle to edit4 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit4 as text
%        str2double(get(hObject,'String')) returns contents of edit4 as a double
function edit4_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
L_str=get(handles.edit2,'String');
W_str=get(handles.edit3,'String');
H_str=get(handles.edit4,'String');
R_str=get(handles.edit5,'String');
L=str2num(L_str);
W=str2num(W_str);
H=str2num(H_str);
R=str2num(R_str);
t=linspace(0,2*pi,300);
rin=R;
rout=W/2; % virtual circle
rout_temp=sqrt(2)/2*W; % radius of circles in two sides
center=[0,0];
xin=rin*cos(t);
yin=rin*sin(t);
xout=rout*cos(t);
yout=rout*sin(t);
xout(1:floor(size(xout,2)*(atan(W/L)/(2*pi)))+1)=L/2;
yout(1:floor(size(xout,2)*(atan(W/L)/(2*pi)))+1)=L/2*(tan(t(1 :floor(size(xout,2)*(atan(W/L)/(2*pi)))+1)));
xout(floor(size(xout,2)*(atan(W/L)/(2*pi)))+2:floor(size(xout,2)*(1/8))+1)=W/2./(tan(t(floor(size(xout,2)*(atan(W/L)/(2*pi)))+2:floor(size(xout,2)*(1/8))+1)));
yout(floor(size(xout,2)*(atan(W/L)/(2*pi)))+2:floor(size(xout,2)*(1/8))+1)=W/2;
xout(floor(size(xout,2)*(1/8))+2:floor(size(xout,2)*(3/8)))=rout_temp*cos(t(floor(size(xout,2)*(1/8))+2:floor(size(xout,2)*(3/8))));
yout(floor(size(xout,2)*(1/8))+2:floor(size(xout,2)*(3/8)))=W-rout_temp*sin(t(floor(size(xout,2)*(1/8))+2:floor(size(xout,2)*(3/8))));
xout(floor(size(xout,2)*(3/8))+1:floor(size(xout,2)*(pi-atan(W/L))/(2*pi)))=W/2./tan(t(floor(size(xout,2)*(3/8))+1:floor(size(xout,2)*(pi-atan(W/L))/(2*pi))));
yout(floor(size(xout,2)*(3/8))+1:floor(size(xout,2)*(pi-atan(W/L))/(2*pi)))=W/2;
xout(floor(size(xout,2)*(pi-atan(W/L))/(2*pi))+1:floor(size(xout,2)*1/2))=-L/2;
yout(floor(size(xout,2)*(pi-atan(W/L))/(2*pi))+1:floor(size(xout,2)*1/2))=-L/2*tan(t(floor(size(xout,2)*(pi-atan(W/L))/(2*pi))+1:floor(size(xout,2)*1/2)));
xout(floor(size(xout,2)*1/2)+1:floor(size(xout,2)*(pi+atan(W/L))/(2*pi))+1)=-L/2;
yout(floor(size(xout,2)*1/2)+1:floor(size(xout,2)*(pi+atan(W/L))/(2*pi))+1)=-L/2*(tan(t(floor(size(xout,2)*1/2)+1:floor(size(xout,2)*(pi+atan(W/L))/(2*pi))+1)));
xout(floor(size(xout,2)*(pi+atan(W/L))/(2*pi))+2:floor(size(xout,2)*5/8))=-W/2./(tan(t(floor(size(xout,2)*(pi+atan(W/L))/(2*pi))+2:floor(size(xout,2)*5/8))));
yout(floor(size(xout,2)*(pi+atan(W/L))/(2*pi))+2:floor(size(xout,2)*5/8))=-W/2;
xout(floor(size(xout,2)*(5/8))+1:floor(size(xout,2)*(7/8)))=rout_temp*cos(t(floor(size(xout,2)*(5/8))+1:floor(size(xout,2)*(7/8))));
yout(floor(size(xout,2)*(5/8))+1:floor(size(xout,2)*(7/8)))=-W-rout_temp*sin(t(floor(size(xout,2)*(5/8))+1:floor(size(xout,2)*(7/8))));
xout(floor(size(xout,2)*(7/8))+1:floor(size(xout,2)*(2*pi-atan(W/L))/(2*pi)))=-W/2./tan(t(floor(size(xout,2)*(7/8))+1:floor(size(xout,2)*(2*pi-atan(W/L))/(2*pi))));
yout(floor(size(xout,2)*(7/8))+1:floor(size(xout,2)*(2*pi-atan(W/L))/(2*pi)))=-W/2;
xout(floor(size(xout,2)*(2*pi-atan(W/L))/(2*pi))+1:size(xout,2))=L/2;
yout(floor(size(xout,2)*(2*pi-atan(W/L))/(2*pi))+1:size(xout,2))=L/2*tan(t(floor(size(xout,2)*(2*pi-atan(W/L))/(2*pi))+1:floor(size(xout,2))));
z1=0;
z2=H;
n=30;
figure
hold on
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/113733184
